oddly, when I raise the driver side PW on my '02 vert, the passenger window will go down! I can put it up by pushing both passenger window controls at the same time... if the driver side is part way down, and I raise or lower it, the passenger side will go down (if it's up)....if both windows are up, and I lower the driver side, soon as it hits bottom the passenger side will go down....
I had some issues with the connection in the accordian boot in the driver's door, fixed that up a while ago, dosn't seem to be the problem this time, a few years ago the dealer replaced all my power window switches under warranty because they didn't light up at night...
all else is good... any similar stories out there?
Thanks!
Do you have a WINDOW VALLET? If the answer is YES,, disconnect it and see if that resolves the issue.
If NOT,, Check the DTCs in the DIC and see if you have any BCM or Door Control DTCs.
For the drivers side to operate the passengers side, you could have a bad passenger switch that is very sensitive
I have to dig into the door schematics but, the BCM could be involved.
Look in the passengers foot well to the left of the BCM. Find the thin grey STAR Serial Data Buss connectors. Pop the top off the connector with FOUR wires and see if the problem still occurs.
