Auto trans /diff
Old May 24, 2012 | 09:51 AM
Driwash's Avatar
Driwash
Default Auto trans /diff
Just check my vett vin and found tha it has 4L60E and a 3.15 diff. it shows as a proformance up grade. Is it true that most come with 2.73 diff?
Can some one give the a run down on this set- up. Want to learn some about the trans also. It is a 1997.
Thank you,
Tom
Old May 24, 2012 | 12:50 PM
RonSSNova's Avatar
RonSSNova
Every auto trans in the C5's was a 4L60E. Electronically controlled of course, hence the E suffix.
The 4L60 is the non electronic version.
Both are decendants of the 700R4.
For the most part, the later the trans the more improvement GM made to it.
Even the best one in stock trim needs beefing for serious performance use. Parts are well supported in the aftermarket.
The 3.15 was the best ratio available for the auto trans cars. A 3.42 diff from the stick cars bolts right in.
Ron
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Yes the 2.73 is the stock gear ratio
A 3.15 was avail as an option --often called the "sport gear"
The 2.73 /A4 in my opinion was a horrible GM combination---On paper the car has the capability to run 200 MPH+ --- but realistically it would take APPRX 600 RWHP or better to do so--
Around town the car feels sluggish and way too high geared-- lugs alot--and on the freeway once it gets going above 60 MPH it's not to bad but quickly runs out of power around 125 MPH--
Even if you go to a stall conveter to get some bottom end torque --the gearing is just too tall and the converter companies won't even reccomend one --( they typically break and overheat horribly)
IF it were my car------I would drop in a 3.42 "take-off" rear end off a Z06 car--They can be found easily--I got mine for $600 and it only had 6000 miles on it !! Installed it myself but you can get it installed for another $300-400----It would make a HUGE difference in the feel of your car--and make it fun to drive !!!!
Old May 24, 2012 | 02:58 PM
Driwash's Avatar
Driwash
Thanks for the info, anyone else have some more info please post.
Tom
To Auto trans /diff
