A4 transmission trouble!
There is another issue, the traction control light is stuck on too. Would that have anything to do with the transmission and how do i fix that?
thanks
Spence
You can rebuild your current one but have to make sure that not just the clutches are being replaces but also your pump and valvebody are checked / replaced. Then it makes perfect sense to rebuild with performance parts. Bu be sure to put matching modifications into the trans since you can create some combinations of parts that won't work very well.
500hp is a serious target for an 4l60e trans. If you don't want to gamble with a diy rebuild, I would suggest to use a reputable trans builder.
Depending on what your budget is, even done yourself you won't get a 500hp capable trans rebuild under $1500, pay double if you outsource.
Good luck
Alex
You can't go wrong with RPM, they have different levels to choose from too:
http://www.rpmtransmissions.com/#!__master-page-1
Thanks,Matt
