need a some electrical help driver side door
Old May 27, 2012 | 12:30 AM
209TIME!!!'s Avatar
209TIME!!!
Default need a some electrical help driver side door
I took my door panel off the other day i unplugged the window control switch, then i got my test light and started testing the pins for power, i found power at the solid orange wire, i was going to tap into that wire for something that i was going to hookup but i changed my mind. so to make a long story short i put it back together and now none of the lights on my control switch work, all the functions work, windows, door locks, power mirrors and memory seats, JUST NO LIGHTS...
i have no clue where to start looking please help that is really driving me nuts.
thanks for any help Anthony
Old May 27, 2012 | 02:47 AM
DeeGee's Avatar
DeeGee
Here's the wiring diagram. Looks like the gray wire for the illumination function. Did you bend a pin on the door switch?
Old May 27, 2012 | 03:00 AM
209TIME!!!'s Avatar
209TIME!!!
None of the pins got bent, is there a fuse for that particular light function?
Old May 27, 2012 | 08:37 AM
65GGvert's Avatar
65GGvert
You should have 12 v on the orange wire going to the lamps. The orange or gray wire, one or the other is not making connection to your door switch panel.
Old May 27, 2012 | 09:19 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Fuse 33 in the passenger footwell fuse box
Old May 28, 2012 | 12:07 AM
209TIME!!!'s Avatar
209TIME!!!
all my connections seem to be good, also i am not getting any power from the orange wire anymore with my test light.
i will check that out tomorrow thanks
To need a some electrical help driver side door
