Fuel Pressure Gone - help
Old May 27, 2012 | 12:36 PM
Crunchking's Avatar
Crunchking
Default Fuel Pressure Gone - help
I have a 98 supercharged vette. Went to pick up car after some body repair and no fuel pressure. I have a hi-flow pump in the tank and a boost a pump. The boost a pump keeps blowing its fuse as soonas you turn the key on. Any ideas? Would a bad Fuel pump blow the boost a pump fuse?
Old May 27, 2012 | 12:38 PM
lucky131969's Avatar
lucky131969
Really helps if you provide details... Which BAP, model, etc? What body work? What repairs were done exactly? Which fuse is blowing?
Old May 27, 2012 | 01:08 PM
Crunchking's Avatar
Crunchking
Sorry, I don't post often. I don't remember the boost a pump model. It was a red, finned non-adjustable model for over 500hp engines. The engine puts out 547rwhp. I had the rear bumper and driver's side rear panel replaced afer a semi drifted over into me on the highway. No damage other than the two body parts were ground down by the semo wheel. The fuse that is blowing is the boost a pump fuse. I haven't heard about the boost apumps ever failing so I was wondering if the in tank pump failed, would that short go bakc to the boost a pump module and blow its fuse? I have checked at the tank fule pump connection and I am getting power back there.
Old May 27, 2012 | 01:11 PM
Crunchking's Avatar
Crunchking
I guess what I should ask is how can I check to see if the in tank fuel pump is bad without taking out the pump?
Old May 27, 2012 | 01:17 PM
lucky131969
I could pull up a schematic for the BAP, if I knew which one it is. Even a picture would help, and knowing if there is a full harness install, etc. To isolate the pump, you can simply unplug the connector from the left pump, and see if the fuse blows. If you can provide info about the BAP install, I can help....if not.....just guessing how it's wired.
Good luck.
Old May 28, 2012 | 12:20 PM
Crunchking's Avatar
Crunchking
Lucky,
The pump is a MSD 2350. The fuse it is blowing is on the boost a pump pwr wire between the pump module and the relay for the module. We replaced the relay and the fuse blew again as soon as the key is turned to On. I'm thinking it is a bad boost a pump module. When the car was in the shop the battery terminals were dirt and they said they clicked the starter a bunch before I told them to check the cables. I'm thinking the constant on and off, and the battery not being grounded properly may have been the culprit.
Old May 28, 2012 | 12:43 PM
lucky131969
Lucky,
Ok. I have a schematic now. Did you follow my last suggestion....unplugging the fuel pump itself?
Old May 28, 2012 | 12:51 PM
Crunchking's Avatar
Crunchking
Yes, we tried that. No difference. As soon as we turned the key on, it popped the module fuse.
Old May 28, 2012 | 12:55 PM
lucky131969
Ok, so that means you either have a short on the power wire, or a bad BAP.
PM sent.
Old May 28, 2012 | 01:14 PM
Crunchking's Avatar
Crunchking
That is what I am thinking. Evidently, MSD BAPs have a bad rap. This one has lasted about 4 years. It is probably time for a Kenne Bell BAP.
Old May 28, 2012 | 01:19 PM
lucky131969
You cannot come to that conclusion, until you have completely isolated the BAP....which you have not done yet. I sent you a PM with my number.
To Fuel Pressure Gone - help
