Convertible trunk question
Trunk Popper for a Vert or Z06
This is an easy mod but for those of you who prefer to buy the ready made item it sells for a very reasonable price of $15.95 from one of the Forum vendors. Unfortunately the vendor doesn’t ship overseas so I needed a DIY version:
http://www.c5trunkpopper.com/
If you want to try yourself, pick up a 7/8” compression spring from Home Depot. They retail at $3.98 for a pack of 4 springs, 2 large and 2 small. You’ll also need an end cap of the same diameter. I used a 7/8” rubber stopper ($1.76). The advantage is that it acts as a soft buffer and can be trimmed to fit.
Cut the large spring to a length of 2”. The springs are quite strong so it takes a bit of elbow grease to cut it. Tighten the radius at the cut end of the spring to give a hole to fasten the screw through.
Undo the T30 torx screw on the right hand side of the closure plate. Insert the torx screw down the barrel of the spring and retighten it in place.
Slot the bung in place. You can trim the bung to get whatever fit you prefer. With it as shown it takes a good push to close the trunk. Trimming the bung will make it easier to close..
It took 10 minutes and all the lubrication and fiddling with the lock are a thing of the past.
I just installed the gas springs, now I have to push the lid closed from the fully opened position and it stays up when opened.
...OP...WD40 is your friend
