Problem with my starter!
Old May 28, 2012 | 06:33 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default Problem with my starter!
I had to take my starter off today and when I took the small wire off I sheered the stud that it attached to. After looking hard and trying to get the stud out I gathered that the stud was attached internal and would not come out. Does anyone have a quick fix that I can do? Can I solder the terminal to what is left or will that cause problems? Can this be disassembled and fixed?
Old May 28, 2012 | 08:43 PM
m6 c5's Avatar
m6 c5
Just from looking at the solenoid it looks as if it is a non rebuildable one and you arent supposed to take them apart.
However if you can solder your signal wire to it I dont see why it would give you any trouble unless it came off. Or you can probably buy a new solenoid for ~40$.
Old May 28, 2012 | 08:47 PM
lucky131969's Avatar
lucky131969
Solder to rusted steel...good luck with that. You'd have to clean it up, and tack weld it... Just change the solenoid....and call it a day.
Old May 28, 2012 | 08:50 PM
m6 c5's Avatar
m6 c5
Never said it was a good idea.
Old May 28, 2012 | 08:55 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
HAHA I looked for someone local with a solenoid and there was nothing avail. so BHRZO6 is shipping me his starter tomorrow CHEAP!!!! I figured it was a lost cause but maybe someone might have a fix worth trying. I hate to throw in the towel and buy a new one because of a stupid bolt. I am dead in the water now i guess till the new one arrives.
Old May 29, 2012 | 03:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I know AUTOZONE has the starter solonoid here in CT. I also know most any Alternator/starter repair shop will have one also.
Try that.
IF,,,,,,,,,, you change out the solenoid, you will need a thin wall DEEEEEEEP well socket to fit the small screw on the lower bolt for the solenoid. A standard socket or wrench will fit the two upper ones just fine.
C5 Solenoids are very well known to develope HEAT related issues over time. They also are well known to stick and not engage unless you bang the damn thing with a wrench.
Highly recommended to hunt down a new solenoid and install it..
Bill
To Problem with my starter!
