problem with front lowering bolt
Old May 29, 2012 | 03:27 PM
upser23's Avatar
upser23
Default lowered pics
Ive read up on lowering the c5 and everything was going perfect till i came to the front driver side bolt it won't movie..I had it soaking over night with pb blaster and went back today and still wouldn't turn and i ended up stripping the head..I sprayed it again and ill let it set for awhile since its not my dd but i don't know what to do now..ive heard people using heat so i might try that in a few days but i really don't feel like cutting the bushings which is that last resort or just raise the rest of the bolts back and not lower it..
Old May 29, 2012 | 03:57 PM
RonSSNova's Avatar
RonSSNova
You have to get on the bottom side of it with a big pair of channel locks. That will get it free.
ron
Old May 29, 2012 | 03:59 PM
bumble-z's Avatar
bumble-z
First!!
Make sure that you have your car is safely raised & supported, to where it will not drop & kill you.
I would use a set of very large channel locks or pipe wrench & turn the adjusters from the bottom ( bushing side ) to get the adjuster to screw upwards.
Ideally, if you had another set of after market adjusters on hand, I would unscrew the (messed up ) adjuster out all the way & out of the spring & replace it with the aftermarket one.
Good luck.
Old May 29, 2012 | 04:52 PM
flynhi's Avatar
flynhi
Originally Posted by bumble-z
First!!
Good luck.
I have the same problem and I think the rubber bushing has vulcanized to the spring.
Old May 29, 2012 | 05:34 PM
bumble-z's Avatar
bumble-z
You lift lightly towards the very end of the spring, & try & then slide a puttyknife under the rubber bushing.
Once the knife slides under the bushing, you will then know that the bushing isn't froze to the lower member.
Old May 29, 2012 | 06:13 PM
upser23's Avatar
upser23
Finally loosened it by wiggling the super tight channel locks back forth and kept spraying lube on the bolt while i was doing it..flynhi you need to try that even though you'll probably mess your bolt head up..ill post pics of the car when i get home
Old May 29, 2012 | 06:35 PM
RonSSNova's Avatar
RonSSNova
I actually twisted the hex portion of one of mine off using a 6 pt socket. In my case, it turned out the bolt was bent! So I had to cut it in place and turn the remainder out. And rusted in like crazy to boot. I used heat as well.
In fact, when I got a front Z06 spring used, it had the bolts in it. Neither were frozen, but one of them was also bent. It seems to be an issue no one notices. I did a post on it here some time back.
BTW, these bolts are not available in stock form.
Ron
Old May 29, 2012 | 06:59 PM
upser23's Avatar
upser23
Old May 29, 2012 | 07:00 PM
upser23's Avatar
upser23
looks a lot better
To problem with front lowering bolt
