Two intermittent electrical problems that are driving me nuts
Problem 1: Active Handling will engage when I'm cruising down the highway doing 65-70 mph. I'll feel a slight brake application for about one second and then it's done. It doesn't jerk the car in any direction. This happens ~3 times per week.
Most common fault is the steering position sensor, but from what I've read that usually causes at least one code. Same with the EBCM. I have a VERY respectable dealer here that said w/o a code to start with, all they could do is put labor hours into it. That doesn't work for me. Ideas?
Problem 2: I took a video to demonstrate this problem. This problem happens maybe once a month. It seems to happen EVERY morning after doing a high speed run of 130+ mph. When I turn the key over to the 'start' position I get a no start condition. The starter doesn't turn, you can't hear the fuel pump, etc. After a COMPLETELY random amount of time/tries, everything just magically works like it's supposed to and the engine fires right up. To rule out the neutral safety switch I tried starting the car w/o depressing the clutch and I can hear the fuel pump but the starter never turns.
I saw a diagram of the various ground locations and there are two, one on each side of the car, that look to be around the base of the seat belt mounting point. Are these locations inside or outside the car? The reason I ask is that I also have water leaks that I haven't figured out yet and have had water down behind the seat belt trim and the carpet behind the seats.
I appreciate any help you guys can offer.
Thanks,
Jeff
The next time you have the NO CRANK issue,, whack the starter while you hold the ignition in the START position (with no response) and I bet the starter will crank after it agitated. nIf it does,,,,,,,,,,,,,,,,,,,,,,
That means the SOLENOID is the issue! Very common problem..
BC
I have the same symptoms but I also get a C1287 and occasionally, a C1288. I have a SWPS in the garage and one of these days I'll fit it.
BC
If it is the SWPS, and it most likely is, I want to make darn sure of it before I throw hundreds of dollars at it.
Your SWPS tells the EBTCM what the driver DESIRES the car to steer. LEFT, STRAIGHT or RIGHT in various degrees
The acceleration and YAW sensors tell the EBTCM which direction the car is actually going. If the car is actually going STRAIGHT (zero YAW signal) and you have a SWPS sensor that is faulty and tells the EBTCM that you have XX Left input,,, the EBTCM is going to work the brakes to get the car back to the direction that it THINKS the driver wants to go. Thats where the brake pulsations come from.. SO,,, you will NOT get any codes cause its doing what it was designed to.
IF,, the SWPS starts putting out out of range or NO SIGNAL, that will set an error and a DTC.
BC
BC
We did this over a year ago. No issues since, approximately 10k miles since changing.
Gary
The key to the replacement is to not spin the steering wheel when it is disconnected from the steering rack.
Here is a link that has information on replacing the SWPS.
http://forums.corvetteforum.com/c5-t...on-sensor.html
Hope this helps.
Gary
BC
Bet ya a cold one its the solenoid.
BC
Is it important to get a NEW GM piece, or will I be ok w/a Napa rebuilt?
If it were me,, I would just replace the solenoid. Get one from a starter rebuild shop.
BC
BC
