LS7 in a C5
I had never driven anything remotely as powerful as this and it pulls like crazy. When I read about guys who have boosted set-ups with 800, 1000 or even 1200 hp, I can't even imagine it.
It can be made for less than half of that.
I like the LS-3 motor better can be made into a Monster it has a better block in my book
On top of that you have the appropriate accessories and peripherals (cooling, clutch, brakes, suspension) etc and you see another $5K to $10K walk out the door.
Taking a stock C5 and slapping a blower on is not the most reliable and safest way to get the job done. Even blown setups needed forged bottom ends, decent cooling and inter cooling and beefed up drive trains.
The reality of chasing normally aspirated HP is that is costs money.
The most important thing is that I didn't pay for it; the previous owner did. I probably paid only a $3000 premium over a stock car for all the extras.
Here's the rundown:
Vengeance LS3 418 stroker block
Callies/Manley internals
FAST 92mm intake
Trickflow 235cc heads
Yellow Terra 1.7 rockers
Trickflow pushrods
AR long-tube headers and X-pipe
Custom-ground cam 234/238 .602/.604
60# injectors
Toss in all the fasteners, gaskets, tune, etc., and it starts to add up fast.
You will use an appropriate forged bottom end and appropriate valve train for the intended power/application.
As far as price goes - if you are able to raid your spares bin and do much of the work yourself, then a decent 427ci setup can be had for about $10K - factor in as much as $18,000 if you do none of the work yourself and want the best accessories.
Either way, N/A big cube motors are not the cheapest route to get crazy HP.
Wanted to know how or what is needed to convert it to wet sump?
It's going in my 02 trailblazer & didn't want to run oil lines & sump tank if I didn't have to....
Unless the block has changed since 2006 you will also need to drill for a dip stick. My block needed to be drilled.
How do you go about mounting the oil tank, etc. in a C5? I am toying with the idea of converting mine from wet to dry since I may be pulling it out to freshen it up.
Do you often install stock bottom end LS7 crate motors, or do you replace the stock rotating assembly with forged components?
The bottom line is that neither of these processes are zero dollar options.
If it were me I would look into swapping for a forged Gen III style crank. It's shorter and would have the 24x reluctor you need and you wouldn't need to buy a converter-box, which I have read mixed reviews about (reliability-wise). That way you can keep your pcm plus be able to use the Gen III hardware.
Like the others have said, install an LS2 oil pan, pump (and pickup), front cover, timing chain, and drill the block (dip stick). Only other things I can think of is/are wire harness extensions for your knock sensors (relocates them to the sides of the block), crank sensor extension harness and wire harness adapter for the TB/MAF sensor. Check Racetronix for the wiring adapters. Pretty much plug-n-play and they are first-rate quality.
Seems like Texas Speed and maybe some others (SDPC?) offer a conversion kit that has all or most of this stuff for doing an LS7 installation that's cheaper than buying it all separately. Talk to Matt at TSP, he is VERY knowledgeable on LS7 swaps and can definitely point you in the right direction.
Oh yeah btw, remember the exhaust ports on an LS7's heads are "D" shaped, so any header you buy needs to have an LS7 compatible flange installed. I think all the well-known header companies will do this, but you need to specify in advance. I know Kooks handled mine no problems, and they fit fine.
HTH
