I've change my old automatic transmission for a new one. I've just brought it from the USA.
The transmission is working well but, unfortunately, the temperature of the transmission is not. Every time that I start to enjoy my Corvette, the temperature starts to rise. It's not necessary the constant acceleration, it happens if I just start to go a little bit faster and stronger than the usual.
It's horrible because I can't enjoy my V8 with 360 hp. Anywhere I go I need to go slowly or the transmission temperature is gonna go to 230 ºF rapidly.
Can you have your mechanic perhaps flush the cooler lines?
And also add an auxiliary transmission cooler?
Since you have had 2 transmissions run too hot, I would look into these 2 items.
Did you have the problem with the old one and the new one or just the new one? If it is the new one, make sure there is enough fluid in it. There is a very specific procedure for filling these transmissions.
If it was both, you can try flushing as suggested above and also checking to see if there is anything blocking the radiator or clogging up the fins with debris.
When I had my RPM transmission installed they said to install an extra transmission cooler and said one of the best was the B&M cooler with it's own fan on it. Now the transmission temp. is between 10 and 30 degrees cooler than the coolant temp. even on very hot summer days. That said it still seems you have other problems, but the B&M cooler works great for me.
I have actually eliminated the in radiator cooler from mine and used the largest B&M stacked plate cooler. 11x9x1". I don't have a fan on it, but it is right in front of the AC condenser. Haven't run the car yet but I don't expect any problems. The in radiator cooler will actually heat the trans fluid, it can't cool it any more than the coolant temp.
The C5 takes a bit of inginuity to mount an aux cooler I might add.
REMEMBER the trans fluid is cooled by a bulit in cooler in your radiator---If your engine temp is HOT-- it will transfer that heat to your trans fluid !! You can't cool a tranny under 200* if the radiator is 210* !! Always helps to install a lower engine thermostat
( I prefer the 160*) and Absolutely get a tune to reset the fans to come on earlier --mail order will work ! Not a handheld tuner though---will drop the ttrans temp 20*'s ( assuming there are no trans mechanical issues----
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Make sure there are no kinks in the trans cooling lines that could restrict fluid flow. I do recommend a after market cooler, but the stock cooler should maintain a safe temp unless you tracking or drag racing your Vette. Make sure all the leaves and debris are thoroughly cleaned up under the front so there is no air restrictions through the condenser and radiator. One other thing is you can install a CoolIt that will allow you to turn your high speed fan on before the temps get to high. The cooler you keep the coolant, the cooler the trans fluid.
__________________ Don't forget to check out our products at www.saccitycorvette.com If you like our products, tell others! If not, tell us!
I do have a B&M finned aluminum transmission pan on the A4. The pan has an extra two Qts capacity. I also run Redline D-4 ATF. No other dedicated transmission or engine oil cooler.
On a normal, no stop and go 20 mile drive to work, average speed ~ 45 mph, transmission temperature is 160 to 180 degrees on a cool 60 degree morning, pulling into my workplace parking spot.
Where do you live?? Please check the AC Condenser (cooling coil in front of the radiator) and the actual RADIATOR for dirt SAND, grass, bugs, bags, etc etc......
Use an air hose to blow out any debris that is lodged in the cooling fins.
There is a 1" space between the AC cooling coil and the actual RADIATOR.. Remove the air bridge ducting between the MAF and throttle body and then remove the black plastic cover that covers the radiator and ac CONDENSOR. LOOK DOWN BETWEEN THE TWO AND SEE IF THERES ANY DIRT OR TRASH!!!
I bet you have a ton of accumulated stuff that needs to be blown out and flushed with a garden hose.
With a good clean radiator free to flow air, your cooling temps will stay a LOT lower and allow the trans to keep cool!!
Hi, Bill Curlee!
I live in São Paulo, Brazil. I've done what you said but everything was OK. Nothing is blocking the air flow... I've talked with my mechanic and he is suggesting that we by another radiator just for the transmission... What do you think? It seems to work on his Camaro!
Thank you for your information!
My Corvette is doing, at the same day temperature, more like 190 to 210 degrees (without "hitting the gas"). I'm trying to discover what is wrong but, unfortunately, we don't have someone directly from GM (USA) to take a look.
It's hard work to own a Corvette in Brazil! hahaha... Only a few people know how to work on the car...
solving the high temperature transmission oil problem
I had the same problem the causewas is that the transmission oil pipesvery close to the exhaust , just change the place where the oil pipe goes tothe other side and the problem is solved anwar
Drove the Vette 160 miles today. Outside air temp ranged from 56F to 70F. No freeway driving all two lane in and out of towns. Dic recorded my average speed as 48.6 mph, highest speed was 70mph average mileage 26.7 mpg. Oil pressure ran around 40 psi, oil temp 200F +/- 5F, coolant temp was a constant 192F, transmission temp 179F +/- 5F. Saw 2 other Corvettes, both waved back. Another great day in Michigan! Mike
