Corvette mod hid resistors install
Old Jun 2, 2012 | 07:48 PM
mrfixer's Avatar
mrfixer
Default Corvette mod hid resistors install
I RECEIVED THE HID RESISTORS TODAY FROM CORVETTE MOD BUT HAD NO DIRECTIONS.
whats up with that?
I tried hooking one up piggyback on the positive side of the line before ballast but did not work.
ANYBODY know how are these so pose to be wired?
Old Jun 2, 2012 | 10:36 PM
lionelhutz's Avatar
lionelhutz
they hook between the low beam light power and ground wires. I thought they had plugs on the ends that you just disconnected the HID wires to the low beam socket and connected the resistor in the middle of the wiring. You will only need one. Almost any load is enough to get the headlights to start retracting again.
Old Jun 3, 2012 | 09:23 AM
mrfixer's Avatar
mrfixer
Thanks for responding ,
so hook them between the positive and negative?
Old Jun 3, 2012 | 10:38 AM
mrfixer's Avatar
mrfixer
These are just a resistor.
Old Jun 3, 2012 | 11:06 AM
lionelhutz's Avatar
lionelhutz
Yup, just connect to the positive and negative wires. If they really are 55W resistors then watch how you mount them because they will be hot with the lights on.
Old Jun 3, 2012 | 11:33 AM
mrfixer's Avatar
mrfixer
Thanks My Canuck Friend.lol
Old Jun 3, 2012 | 12:55 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Are these the resistors that require you to tap into the wiring? If so I would toss those out. We offer a plug n play resistor for the HID kits.
Old Jun 4, 2012 | 06:59 AM
sereneDelusions's Avatar
sereneDelusions
Very good tip! I learned this lesson the hard way when trying to mount the thing...left my fingers with grill style marks.
Old Jun 4, 2012 | 09:59 AM
lionelhutz's Avatar
lionelhutz
On another note, I have no idea why the aftermarket insists on you installing 55W resistors to keep the headlights retracting. A couple of watts is more than enough load to keep the headlights retracting. A 100ohm, 5W resistor or a side marker bulb wired to the headlight power would both work just as well.
Old Sep 4, 2012 | 04:18 PM
GCG's Avatar
GCG
I checked your website and found the resistor you mentioned. Could you please tell me how many ohms it has and how many watts it is rated for?
Thanks.
Old Sep 5, 2012 | 10:11 AM
Corvette_Ed's Avatar
Corvette_Ed
I know this is a bit out of date but.....
Old Sep 6, 2012 | 09:24 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
A 100 ohm-5 watt resistor would draw less than 2 watts of power, and not get very hot.
With a couple spice taps, and some shrink tubing, you could make a suitable load resistor for a couple bucks.
Old Sep 6, 2012 | 11:51 AM
GCG's Avatar
GCG
I totally agree, but at the same time I can understand those who prefer a plug-and-play, albeit more expensive, solution like this one from JW Motoring. That's why I was trying to find out its value and power rating.
If all we need to do for the headlights to open and close normally is to draw around 150mA extra, then there is no need to go beyond that and unnecessarily load the circuit with an extra draw of almost 3A when using a 5 ohms resistor, as I've read some people have done.
Does anybody know how many ohms has and how many watts is rated for the plug-and-play resitor mentioned above?
Old Sep 6, 2012 | 12:03 PM
piran21's Avatar
piran21
Avoid in-line resistors. They get super hot and can melt plastic. Careful where you mount them if you use them.
Old Sep 7, 2012 | 03:00 PM
GCG's Avatar
GCG
Originally Posted by GCG
...Does anybody know how many ohms has and how many watts is rated for the plug-and-play resitor mentioned above?
Anyone?
Old Sep 7, 2012 | 05:17 PM
Quicksilver Vert 01
For $25 you could easily find out for yourself.
http://shop.jwmotoring.com/product.s...8&categoryId=4
Old Sep 7, 2012 | 05:34 PM
GCG's Avatar
GCG
I know, right?
Old Sep 13, 2012 | 09:00 PM
jerrad's Avatar
jerrad
Does anyone have a pic of the install?
To Corvette mod hid resistors install
