ac control problem
Old Jun 4, 2012 | 03:14 PM
jpranchranger's Avatar
jpranchranger
Default ac control problem
Has anyone had problem with the ac/heat passenger control on a 2000 c5? Do I need to buy a new one, and if so, how hard is it to pull and replace it?
Old Jun 4, 2012 | 03:17 PM
lucky131969's Avatar
lucky131969
There are many issues documented on this forum. What is your specific issue? Any codes?
Old Jun 4, 2012 | 08:47 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Super easy to replace...but like Lucky asked, what's wrong with yours?
Old Jun 5, 2012 | 02:12 PM
jpranchranger
nothing happens when I use the passenger control ****. no codes show up anywhere either. drivers side temp control works fine and shows on the screen. passenger does not show on the screen at all when you turn the ****.
Old Jun 5, 2012 | 02:54 PM
BigGun's Avatar
BigGun
Check your owners manual. It is not supposed to show on the screen.
Old Jun 5, 2012 | 04:01 PM
Cybermind's Avatar
Cybermind
This always makes me laugh. I'll bet his VCR was always flashing 12:00 in the old days..........
Old Jun 5, 2012 | 05:18 PM
Vettmann17's Avatar
Vettmann17
The Drivers side control **** is what actually sets the temp, all the Pass side control does is increase or decrease the temp by about 5-10 degrees (not sure exactly how much) but it doesnt change the number in the display only the actual pass side air temp. IMO kind of a useless feature since its not a true dual zone climate control like other cars. Anyway, it sounds as if if working as it should, hope this helps.
Old Jun 5, 2012 | 06:35 PM
dgrant3830's Avatar
dgrant3830
You can look at the passenger **** as a slight override to the main temperature setpoint, as set on the driver's side. It does not display anything.
Old Jun 6, 2012 | 05:34 PM
jpranchranger
Thanks everyone. At least now I know. I forget this car is almost 13 yrs old sometimes. The dual ac in my other cars always control the passenger side.
I guess I really am that old guy that has the 12 oclock blinking on my electonics at home...lol
To ac control problem
