rocking seat.
Old Jun 5, 2012 | 08:38 PM
regblkss's Avatar
regblkss
Default rocking seat.
Its not the sliding forward and back. Its the front of my drivers seat goes up and down. I did the rocking seat fix for it sliding back to front. But it still has a up and down only on the front of the seat. And one else have this?
Old Jun 6, 2012 | 09:34 AM
MStrahan's Avatar
MStrahan
I too had the same issue and solved it with a set of Corbeau A4s.
Good luck with the problem solving and if you happen to figure it out make sure and post up what you've found as I'm sure someone else is having the same issue.
Old Jun 6, 2012 | 12:13 PM
alankb's Avatar
alankb
Default Ditto, but...
I was able to get most of the slop out by putting a washer between the seat bracket and a roll pin on either side of this rod which goes side to side. Sorry no pics, but take the seat out and turn it upside down and you will see the movement.
Can't wait to get my A4's installed!
To rocking seat.
