Engine shut off while approaching stoplight
Old Jun 19, 2012 | 07:14 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by JWAddington
.....It mainly acts up when I start to come to a stoplight, when I come to a complete stop the rpms want to drop a touch to low, then it recovers. Sits right around 500-600rpms, but the needle will bounce around, will not be smooth like before. Right now that's the only thing different I have done to the Vette in the short span was clean and oil the filter.
I must have a problem too!!
Mine has done that every once in a while since it was new. It never stalls, but just 'stumbles' for a second or two, then recovers and smooths out....
Old Jun 19, 2012 | 11:43 PM
m6 c5's Avatar
m6 c5
After I fixed my vacuum leak mine would stumble and actually stall until I did an idle relearn procedure.
This is the one I used which I believe was posted by Bill Curlee
AUTOMATIC TRANS:
ign. off
remove pcm batt fuse
wait 5 min
replace pcm batt fuse
a/c off
park brake and block drive wheels(do not use brake)
start vehicle
allow coolant to reach over 176F
shift into drive
wait 5 mins
turn on a/c
wait 5 mins
shift to park
wait 5 mins
turn off a/c
wait 5 mins
turn off engine. off
Old Jun 20, 2012 | 07:15 AM
leadfoot4's Avatar
leadfoot4
AUTOMATIC TRANS:
ign. off
wait 5 min
a/c off
start vehicle
shift into drive
wait 5 mins
turn on a/c
wait 5 mins
shift to park
wait 5 mins
turn off a/c
wait 5 mins
That's good info, although I have a 6 speed car. I'll have to dig out my shop manual and give it a try....
Old Jun 20, 2012 | 05:40 PM
m6 c5's Avatar
m6 c5
Whoops I thought I had the 6 speed info as well, as I have a 6 speed...
Old Jun 20, 2012 | 05:41 PM
m6 c5's Avatar
m6 c5
Im pretty sure its the same just take out the steps that involve shifting and just worry about the AC and water temp.
Old Jun 21, 2012 | 09:38 AM
JWAddington's Avatar
JWAddington
I cleaned the MAF sensor and the throttle body, then did an idle relearn. Took it out for a drive, about 45 minutes, it ran good. I tried everything to get it to stumble, but it didn't.....keeping fingers crossed! Did some hard accelerating, then hit the brakes to get the rpm's to come down fast like they did when it would stall. It went just under 500rpm's and came back up, never felt like it was going to stall or even stumble for that matter.
So far I haven't even felt the surging that used to be present while cruising at a set speed, it all felt pretty smooth!
Now I need to investigate the battery volts on the DIC. They started out at 14.1V....after the relearn it was sitting around 13.6v. During the drive, it didnt like going under load when I was playing with it to see what it would do. I turned the a/c on, headlights, radio etc....it dropped to 11.9V - 12.5v. After I shut all that off it recovered to 13.4 - 13.6v. I'm gonna check out the connections at the starter later today.
Old Jun 22, 2012 | 04:09 PM
JWAddington
I checked out the starter connections, everything was tight and clean, no corrosion whatsoever. The ground that is above the starter was good as well. This Vette hasn't seen rain so everything looked really good corrosion wise. It is mainly a Weekend driver and whenever I have a chance to get in it during the week. 2004 A4 Convertible with just under 20,000 miles.
Volts across battery terminals before start were 12.8....after start 14.1. Let it run for awhile, put a load on it...a/c with fans kicking into high speed dropped the DIC to 12.5 with 13.0 at the battery....always .5 volt difference between the DIC and at the battery, when toggling between load and no load. It hasn't stalled/shut off on me since I did the cleaning posted above, but I don't trust what's going on with the charging system right now. Only code I'm getting is the HVAC 0367H. I reset it and that one is always there.
Old Jun 22, 2012 | 05:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That .5 VDC difference is caused by your ignition switch contacts being dirty or burnt!
You can easily fix it:
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
You could have more severly burnt contacts in the switch that causes stuff like your fuel pump to shut off or slow down.
Bill
Old Jun 22, 2012 | 11:46 PM
JWAddington
Sounds like a fun project! What's a good guess at the time it would take for an ignition switch virgin to do this project on a weekend?
Old Jun 23, 2012 | 09:39 PM
c51stvette's Avatar
c51stvette
I did it a few weekends ago and I would guess that if you jump right into the removal of the switch it might take you 2-4 hours. I took more because I wanted to make sure my problem wasn't related a relay, starter solenoid or ground problem. One of the frustrating tasks for me was wrestling with the removal and reinstallation of the center console.
