LSx Rocker Arm Failure
Old Jun 10, 2012 | 09:28 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Default LSx Rocker Arm Failure
I had a customer come in to the shop last Saturday for a rattling sound from the engine. After further inspection, found that the #4 rocker arm failed. This was a heads/cam C5Z with the stock rocker arms. As part of preventative maintenance, the rocker arm bearing should be replaced.
C5Z Rocker Arm Failure
The stock rocker arms contain 33 bearings on each side and that is a total of 1056 bearings for all rocker arms. In this instance, none were in the head and all have drained to the oil pan. Now, from there, the magnetic drain plug will only capture a few. The other can be floating who knows where. This is cheap insurance and once these fail, they can mess up the valve stem and retainer.
RPT Rocker Arm Rebuild
I have seen occurances were this can trash an engine and have seen it. The rocker has to be replaced since it was destroyed and after the repair, the engine was nice and quiet.
We have the rocker trunion upgrades in stock and offer the core swap, for no down time.
Old Jun 20, 2012 | 01:02 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
All kits were shipped and received 10 more.
Old Jun 20, 2012 | 01:09 PM
Corvette_Ed's Avatar
Corvette_Ed
Both of your links are showing as unavailable.
Old Jun 20, 2012 | 02:23 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
We are changing Facebook Pages and has disabled the current page.
Old Jun 20, 2012 | 03:29 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It has been discussed several times here on the CF, that the OE rocker trunnions are NOT designed for use with cams that have more lift than a stock cam. It's NOT a question of preventive maintenance, that says the OE trunnions should be replaced with the CompCams kits, rather the OE trunnions HAVE to be replaced when a cam with higher lift numbers than stock, has been installed in the engine. An alternative would also be an aftermarket full roller rocker....
Old Jun 20, 2012 | 04:04 PM
Mike94ZLT1's Avatar
Mike94ZLT1
What about the new GM rockers with the caged needle bearings?
Old Jun 20, 2012 | 07:28 PM
ZeeOSix's Avatar
ZeeOSix
What model year did GM start using those?
Old Jun 20, 2012 | 07:37 PM
lucky131969's Avatar
lucky131969
http://forums.corvetteforum.com/1574320136-post20.html
Old Jun 20, 2012 | 08:20 PM
ZeeOSix's Avatar
ZeeOSix
... so what's with the LS7 having rocker arm bearing failures? Didn't GM learn a lesson and not use the captured needle bearings in the LS7?
http://forums.corvetteforum.com/c6-z...ngs-issue.html
Old Jun 20, 2012 | 08:48 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I scrolled through that thread, and in looking at the pictures it appears that issue is with the offset intake rocker, on the offset side. LS7 exhaust rockers are the same as LS1, LS2, and LS6 rockers.
Old Jun 20, 2012 | 11:27 PM
ZeeOSix's Avatar
ZeeOSix
I didn't read through the whole thread, but the photos in this post look just like the un-caged rocker bearings in my 2002 Z06. The race can break, then the needles puke all over the place.
http://forums.corvetteforum.com/1564885933-post5.html
Anyone have a photo of the new GM "caged" rocker arm bearings?
Old Jun 21, 2012 | 12:19 AM
johnbell2's Avatar
johnbell2
I believe we can all agree it's a less than ideal design from the factory. The bearing issue has been observed in stock trim engines, many of which weren't abused. Offset rockers exacerbate the issue as many have seen already. Holding the OE rocker in your hand and shaking it isn't confidence inspiring to say the least... surprisingly sloppy for a part that's supposed to go into a performance engine.
I can agree that waxers and trailer queens can skip this upgrade. People who drive these cars the way they were meant to be driven, however, should consider the trunnion upgrade as reasonable and cheap insurance. Yes, even if they're otherwise stock and yes, especially so if they plan on upgrades as you've noted.
Old Jun 21, 2012 | 12:47 AM
C5Natie's Avatar
C5Natie
PM sent
Old Jun 21, 2012 | 09:00 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
PM returned
Rocker Upgrade Link
Old Jun 21, 2012 | 09:02 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
LS1/LS6/LS2 and LS3 Exhaust Rockers are the same. The LS7 uses a 1.8 ratio rocker and is different.
Old Jun 21, 2012 | 09:04 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Up to 2012, the rockers are cageless including the Camaro ZL1 (LSA). I have not seen any caged bearings from GM.
Old Jun 23, 2012 | 01:41 PM
Mike94ZLT1's Avatar
Mike94ZLT1
See above. New ones I received from SDPC are caged, and look noticeably different than the ones that originally came on my car.
Old Jun 23, 2012 | 08:10 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
The OEM rockers are not caged. Thge caps are pressed in and only in place by friction. Not sure id SDPC is offering upgraded rockers. The 2012 Camaro ZL1 has the some rockers GM has been using since 1997.
To LSx Rocker Arm Failure
