Question about replacing TPMS/DIY bead breaking?!
Old Jun 13, 2012 | 05:38 PM
wcsinx's Avatar
wcsinx
Default Question about replacing TPMS/DIY bead breaking?!
I've had a couple weak TPMS sensors for awhile now that would come and go at times. Well I guess a 120 mile round trip to and from Orlando was too much for them and they've given up completely.
I have 4 new sensors ordered (figured I might as well do them all at once since they're all 10 years old now), and I'd planned on taking them to a local tire joint to get them swapped in. But I've read several posts now on guys just breaking part of the bead loose just far enough down to swap the sensor, and I'm curious as to what procedure one might use for this.
I've broken many a bead loose on my own, but only on things like motorcycles, atvs, and tall pizza cutter car tires using a myriad of techniques involving jacks, 8' 2x4"s, running over them with another vehicle etc. I would think a wide, low profile tire like a C5's would present another set of challenges entirely.
Soooo ... anyone done it? pics?
Old Jun 13, 2012 | 05:41 PM
baxsom's Avatar
baxsom
50 bucks says if they are run flats you cant do it without the proper tools.
Old Jun 13, 2012 | 05:50 PM
Corvette_Ed's Avatar
Corvette_Ed
Think about this for a minute:
If you attempt to break the bead, and screw up the sidewall, or worse, the wheel itself (score, scratch, dent, etc.) you're stuck with a screwed up wheel or tire that you have to pay to replace/repair.
If you take the wheels/tires to a tire shop, and they screw up the wheel or tire, they pay to replace/repair what they screwed up.
Which would you prefer?
This:
Or this:
Old Jun 13, 2012 | 05:51 PM
Mickeyrx70's Avatar
Mickeyrx70
I've done it before, but with proper equipment at the base Auto Hobby shop. My advice is to pay a few bucks & let the pros do it. Also I'd suggest you program the TPMS sensors BEFORE they're installed; just use a Sharpie to label each sensor for the appropriate wheel...eg LF, RF, etc. Good luck!
Old Jun 13, 2012 | 09:43 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Even if you were somehow able to break the run flat tire beads, pushing those stiff sidewalls in far enough to reach the sensors would be another challenge.
To Question about replacing TPMS/DIY bead breaking?!
