Cheapest way to cam?
Old Jun 16, 2012 | 07:35 AM
AU N EGL's Avatar
AU N EGL
"cheap" and "muscle car idle",
take a screw driver and punch some holes in your muffler.
Sorry, but you get what you pay for.
Old Jun 16, 2012 | 07:54 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by Tech
I fail to understand the logic that a custom grind camshaft is a "cheap" way to go, nor do I think any additional cost is worth the effort. Most off-the-shelf grinds are designed for bolt on C5s. Odds are, that it won't be the last mod he buys for the car, negating the very small benefit (if any) he got from a custom grind.
When you buy a cheap kit you get exactly what you pay for. A kit with cheap parts in it.
Old Jun 16, 2012 | 08:58 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Originally Posted by NukeC5
I agree. Kits are the way to go. Custom grinds bring negligible benefit for the price. Buy the kit because it is pieced together for cheapness already and install it yourself if you are mechanically inclined.
Custom grinds aren't really custom, call Comp or go to the website and look up intake/exhaust lobe #'s..........that along with advance and LSA selection..........
Are there 'ONE-OFF' true CUSTOM grinds, maybe.....but 95% of the cams coming from Comp are just picked from the catalog............either custom or off the shelf
Pricing, same price
Old Jun 16, 2012 | 09:23 AM
Paul 75 L82's Avatar
Paul 75 L82
I just posed my list for everyone's use, I wasn't trying to go cheap. I also had a $500 dyno tune that wasn't on the list.
Old Jun 16, 2012 | 10:14 AM
dbartromvette's Avatar
dbartromvette
Good thread. I am getting ready to order everything for my cam swap. I want it reasonably priced. But, I do want it to be reliable. I have been doing quite a bit of research and am looking for a cam that makes a lot of low end torque with decent peak hp. I too want the muscle car sound. I am thinking TSP 228r 112 lsa and the TSP headers. I am going to have Mike Norris do the tune down in indy when I'm done with the install.
Hoping for 400rwhp. I also have I/E done.
Old Jun 16, 2012 | 10:33 AM
ZZ06's Avatar
ZZ06
TSP's kits are great! I have PLENTY of buddies running their kits and make great numbers. One of my buddies made 440/380 with the good ole MS4 cam only on his 03ZO6. TSP starts you out with a basic kit. You can pick and pull what you want to add or upgrade from there. ALL of my cam parts cam from them.
Originally Posted by SteveDotenMotorsports
Not sure why everyone chases down cam "KITS"?, I guess it's the easiest way, easy is often the path chosen by many
I prefer to contact your local tuner, they will have experience and often are part of a 'network' of other LS tuners
I have consulted Don Kinder since 2006 on cam selection, I also consult Bret Bradbury(he has built many 800hp C5's and drives a 1200hp C5Z)
COMP cam grinds will run 375-450; the margins are "LITTLE", the margins and power under the curve you could gain from the "OPTIMIZED" grind are HUGE
NEW PARTS:
Crank pulley(how many pulleys have we seen wobble/fail), UD pulley is honest 5-8whp..........how about than nice oil spewing groove that is in 1 of 5 or so??)
CHAIN, LS2/3/7 chain is about $45
OIL PUMP, LS6 pump is about $130
GM Blue O-ring/front crank pulley seal/front cover seal, $40
PUSHRODS, stock can be used pending cam selection(don't quote me, I've seen it firsthand from one of the largest shops on the eastcoast)
Valvesprings, NOT AN OPTION; Pac, PSI, Comp along with new seals
LIFTERS................this is HUGE, I'm seeing more lifters failing now when the cars are getting close to the 100k mark; the replacement is known as the "LS7", but is just the lifter that now supersedes the LS1/2/3/6 lifter..........along with lifter trays($20 for all 4!!!!!!!), mine as well grab some 241 for $100 if you have a 97-00 or some 243's for 4-600(Cyl. head removal IS required for lifter R2)
Bottom Line: do the research, feel free to PM me with any questions
YES!!!!! I JUST had this problem. I knew it, damnit all to hell i knew it. When somthing went it was only gonna be one of 2 parts. I upgraded everything but the lifters and rockers. I have a lifter going bad on the #5 cylinder. 01ZO6 and she has 105k on her. Been Cammed since 83k.
lessoned learned.
Old Jun 16, 2012 | 03:12 PM
C5Natie's Avatar
C5Natie
I give my vote for TSP's cam kits. Those guys really do a lot of testing when putting their cam combos together. Even the basic components in their kits are quality parts. Very friendly and helpful customer service as well.
Btw for those who may worry about different pushrods lengths when using the LS7 lifters, Melling makes a good quality oem replacement lifter for LS1's. Made in the USA and available at most auto parts stores.
