Will this cam require fly cut pistons?
Old Jun 17, 2012 | 09:45 PM
Speedaemonc4's Avatar
Speedaemonc4
Default Will this cam require fly cut pistons?
Hey I was wondering if anyone knows off hand if this cam requires fly cut pistons, its pretty big so I wasnt sure and dont wanna rebuild my motor.
http://www.compcams.com/Company/CC/c...csid=1412&sb=0
Thanks in advance!
Old Jun 17, 2012 | 10:37 PM
Nate B's Avatar
Nate B
What other mods do you have? Stock, aftermarket, milled heads? What size valves?
Old Jun 18, 2012 | 07:49 AM
Speedaemonc4
All stock ls1.
Old Jun 18, 2012 | 08:06 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by Speedaemonc4
All stock ls1.
No offense
TOO big of cam for a stock LS1. ie Over cammed
241 heads do not flow much above a cam lift of .575.
running a smaller cam will get much more out of the LS1.
220/224 http://www.compcams.com/Company/CC/c...csid=1087&sb=2
224/230 581/588 with a 114+2 may get you more hp out of the LS1 then the bigger cam above
http://www.compcams.com/Company/CC/c...csid=1092&sb=2
You will need new springs, new timing chain, new push rods, and a dyno tune to make it all work
Good Luck
Old Jun 18, 2012 | 01:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by AU N EGL
No offense
Good Luck
VERY GOOD RECOMMENDATIONS!
BC
Old Jun 18, 2012 | 01:41 PM
Nate B's Avatar
Nate B
Also that cam is designed for rectangle port heads. I wouldn't go that that big of a cam anyways. I have 3 cams in my 02z ranging is size from 230 to 250 duration. The smaller cams made more power and had better driveability.
Old Jun 18, 2012 | 08:21 PM
JohnJ@Texas-Speed's Avatar
JohnJ@Texas-Speed
Premium Supporting Vendor
I think there is a decent chance the cam might fit, but I agree with these other guys in saying that it is probably too big specs wise. Something with a little less duration will work much better as far as power and drivability. We have very solid results from our 228R(228/228 .588/.588) cam over the years, I highly recommend it for any street driven corvette.
Old Jun 19, 2012 | 06:47 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Too Big!
That cam is too big for your LS1.
i'm putting a similar cam in my ERL 454 with WCCH LS3 heads. Yoy might want to look at the cams suggested by AU N EGL.
Bob K
Old Jun 19, 2012 | 08:57 AM
Speedaemonc4
Thanks for all the advise guys, there is no offense taken, I wanted advise and appreciate it. Since I posted the other day the wife and I had a discussion and she feels its time for the vette to pull its weight since our jeeps motor went south. Any reccomendations for a cam that's bigger than an ls6 but won't require 30,000 mile spring changes or break my torque tube couplers, diff, etc? Just enough to keep me ahead of the newer faster stock cars ya know.
To Will this cam require fly cut pistons?
