Intermittent Computer PCM codes
Old Jun 19, 2012 | 12:14 PM
87convpaul's Avatar
87convpaul
Default Intermittent Computer PCM codes
What causes my 2001 with 55,000 miles to have these codes P0171 & P0174 come and go?
Old Jun 19, 2012 | 12:25 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
These are both LEAN codes one left side one right--Typically they are a result from adding mods such as cold air intakes--Also check for vacuum leaks or any intake air tract leak in the air bridge assy.--- If you can get a scanner check to see where your LTFT fuel trims are--To get a lean code usually means the trims are beyond +20 %-
Go to this site to review diagnostics---
http://www.gearchatter.com/viewtopic8886.php
Old Jun 19, 2012 | 01:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What MODs do you have???
Have you checked the PCV elbow for rot/damage that can cause a big vacuum leak?
Ducting between the MAF and the TB for air tight status.
BC
Old Jun 19, 2012 | 05:01 PM
FKING1's Avatar
FKING1
My highly modified 2000 will throw the P0171 if the motor idles for around 5 min. If I drive off it doesn't. Has been doing this for several years. My mechanic tried to find the prob with no success. No leaks evident.I just reset the code and forget it.
Old Jun 19, 2012 | 09:59 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Fred, that is from a cold start, right?
Old Jun 20, 2012 | 05:02 PM
FKING1's Avatar
FKING1
Yes, from a cold start.
I rarely get the code on a hot start.
Old Jun 22, 2012 | 01:13 AM
87convpaul's Avatar
87convpaul
The only mod is the K & N cold intake & BB exhausts/
Old Jun 22, 2012 | 01:19 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ONLY real way to get to the bottom of your issue is to DATA LOG the PCM and see where specific sensor outputs fall.
The major sensors to monitor would be:
LTFTs
O2 Sensor Output Data
WIDE BAND O2 sensor readings
One or more of those values will be WRONG and will be easily seen.
Bill
To Intermittent Computer PCM codes
