Code B0 RFA U1064h
Old Jun 21, 2012 | 08:56 PM
Smooth's Avatar
Smooth
Default Code B0 RFA U1064h
Where is this problem?
I know it means Loss of communication, but, What does B0 RFA mean?
Right Front Axle ???
I'm dealing with an Service Active Handeling Alert and a 1288 code. If the code above is related, then it could be one of those wires near the right front wheel?
Help!
Alan
Old Jun 21, 2012 | 11:36 PM
byronhunter's Avatar
byronhunter
Cut and Paste right out of the Service Manual.
RFA Remote Function Actuation
Old Jun 22, 2012 | 09:24 AM
Smooth's Avatar
Smooth
Thanks guys. I've tried clearing that code, but, it always returns. Tire pressure still registers on all4 wheels, Hatch lid pops from the key fob and doors lock and unlock from the fob ?????
after turning the steering wheel right to left and left to right all the way to lock, the 1288 code seems to stay away longer....that code with the Service Active Handling message come on with a good bump so maybe its a ground problem. I'll start cleaning today....wish me luck.
Old Jun 22, 2012 | 09:35 AM
Corvette_Ed's Avatar
Corvette_Ed
Or it's a problem with the wires leading to the ABS sensor on the wheel hub. Check to make sure all are secure and not cut.
Old Jun 22, 2012 | 09:44 AM
lucky131969's Avatar
lucky131969
Why do you think a wheel sensor issue/wiring would precipitate a C1288 code?
Old Jun 22, 2012 | 10:09 AM
Corvette_Ed
Just a guess because of the Service Active Handling indicator coming on when he hit bumps. I had a similar incident in the past and it turned out to be the wiring leading to the ABS sensor. I'm not necessarily saying it's a cause of the 1288 code, but the indicator coming on could be the result of a wiring issue. It doesn't hurt to check; I've seen stranger things happen.
Old Jun 22, 2012 | 10:18 AM
DeeGee's Avatar
DeeGee
I finally traced my C1288 to a bad steering wheel position sensor.
Old Jun 22, 2012 | 10:28 AM
lucky131969
Three things happen in concert with a C1288 code:
1) ABS and TCS stay working, A/H is disabled
2) Indicators in IPC turn on
3) DIC message displays : "Service Active HNDLG Service Vehicle Soon"
If you don't have a full understanding of the system, it does not help those troubleshooting.....rather...it can send them on a wild goose chase. Not trying to give you a hard time here, but try hanging out and reading a while....instead of posting "guesses".
Old Jun 22, 2012 | 10:47 AM
Jeff in Den's Avatar
Jeff in Den
RFA: Remote Function Actuation system allows transmitter remote contol of various vehicle systems without physical actuation of the switches. The RFA does not directly control system functions, but uses the BCM, or DCMs to intiate system functions.
DTC U1064: Loss of communication with the BCM
Each system on the serial data line is assigned its own recognition code which is used to identify which system is communicating. Systems periodically send SOH (state of health) messages to other systems via the BCM. If no response is received by those systems a corresponding DTC will be set, and any system that connot communicate properly will set the corresponding DTC. DTC U1064 will set when IPC has sent a SOH message to the BCM and no SOH response is sent back for 5 seconds...No driver warning message will be displayed. DTC U1064 requires an ignition cycle to change form current to history, and if the problem no longer exists, the history DTC will clear after 50 consecutive ignition cycles or a scan tool is used to clear the code.
DTC C 1288: Steering Sensor Circuit Malfunction
The steering wheel position sensor provides the EBTCM wih a voltage of 0.2-4.8 volts depending on steering wheel angle. The DTC will set when the voltage is out of range, and the ABS/TCS will be disabled. The ABS and TCS indicator lights will illuminate.
The malfunction can be caused by a short or open steering wheel position sensor circuit. Inspect the wiring and connectors.
The loss of comms with RFA may impact TCS IF ABS/TCS is disabled from the C1288 code.
Old Jun 22, 2012 | 10:54 AM
BigGun's Avatar
BigGun
That code indicates a problem with your steering wheel position sensor. Its operation can be checked with a tech II or if your very good a DMM. It will most likely need to be replaced. It is located near the bottom of the steering column inside the car.
Old Jun 22, 2012 | 12:08 PM
lucky131969
Originally Posted by 8VETTE7
I guess I fail to see how a system (RFA) that deals with the signals from the Keyless remotes and TPMS, loosing its communications to the BCM, can impact TCS. Perhaps you can eloborate on how that happens please.
I never said it did, just responding the the C1288 code the OP posted, and clarifying misinformation...
Old Jun 22, 2012 | 12:11 PM
Jeff in Den
Should have been Active Handling.. not TCS. No SOH from TPMS (no comms from RFA)
my bad..
Old Jun 22, 2012 | 01:31 PM
Corvette_Ed
I guess the part where I said that I'd had a similar experience that turned out to be the wiring just went right past you. Electrical shorts + computer modules = some really funky possibilities.
Occam's Razor. If you're not familiar with the term you should look it up instead of saying someone who was trying to be helpful should just shut up and pay attention.
Old Jun 22, 2012 | 02:17 PM
lucky131969
Yes, I am familiar with the term.....which is based on the simplest answer being correct. Applied in this case, it would be the steering position sensor, as there is a specific code for that malfunction.
I never stated that you should "shut up, and pay attention".....rather, have an understanding of what you are talking about, coupled with specific experience, to help someone solve a specific problem. Guessing does not help anyone.......period.
So you not only read my post wrong, and then regurgitated it in what you think it meant, so I can only surmise that you are a woman. That being said, I will be more careful in my phrasing when addressing you.
Old Jun 22, 2012 | 02:28 PM
Corvette_Ed
That's only part of its application, and not it's full meaning.
"The simplest of two or more competing theories is preferable and that an explanation for unknown phenomena should first be attempted in terms of what is already known."
Once the probable has been ruled out, the simplest of the improbable is most likely the answer. I provided the simplest of the improbable, since it has already proven to be the correct answer in my case, and not a guess. Improbable does not mean impossible.
And yeah, there's all kinds of women going by the name Ed.
Old Jun 22, 2012 | 02:37 PM
lucky131969
Ok then..........shut up, and pay attention.
Old Jun 23, 2012 | 12:57 PM
Corvette_Ed
No.
To Code B0 RFA U1064h
