C5 a/c controls
Old Jun 22, 2012 | 03:53 PM
FRITZM's Avatar
FRITZM
Default C5 a/c controls
A/c runs and blows cold driver side, but blows warm on passenger side. Cure - suggestions? Tia
Old Jun 22, 2012 | 04:11 PM
jrose7004's Avatar
jrose7004
The 98 coupe I used to have did that when it needed freon. Try search as this problem is discussed about once a week during the summer season.
Old Jun 22, 2012 | 04:13 PM
jrose7004's Avatar
jrose7004
http://forums.corvetteforum.com/c5-t...passenger+side
http://forums.corvetteforum.com/c5-g...passenger+side
Old Jun 22, 2012 | 04:30 PM
FRITZM's Avatar
FRITZM
Default A/c cure
Thanx, i read one of the posts and it just may be the right medicine.
Old Jun 22, 2012 | 05:38 PM
jrose7004's Avatar
jrose7004
Old Jun 23, 2012 | 12:05 AM
Jeff in Den's Avatar
Jeff in Den
Do you have any hvac codes? Common problem is the actuator going out of range due to a broken plastic gear. Re-index them first, if that doesn't work and you still have codes it's the actuator. One for each side, change the one the code is calling out, or you can try and rebuild the gear.
Old Jun 23, 2012 | 12:15 AM
FRITZM's Avatar
FRITZM
Default A/c cure
I'll give it a try. Can't hurt might help. Late now try tomorrow. Thanx.
To C5 a/c controls
