LED Blinker/Flasher Install
Old Jun 23, 2012 | 10:46 AM
mikecampi's Avatar
mikecampi
Default LED Blinker/Flasher Install
I just installed the LED rear tail lights. Can any of you guys send me or show me where the install instructions(with pictures if possible) of detailed instruction on how to hook up the hyper flasher/blinker relay? I know you have to pull off the knee bolster, but thats as much as i can figure out.
Thanks!!
Old Jun 23, 2012 | 12:12 PM
headhawg's Avatar
headhawg
Before someone tells you to use the Search function, try this thread: http://forums.corvetteforum.com/c5-g...per-flash.html
Old Jun 23, 2012 | 12:55 PM
99 vett babycar's Avatar
99 vett babycar
that's what i used. not hard to do and it works.
Old Jun 23, 2012 | 02:02 PM
mikecampi's Avatar
mikecampi
Thanks... but.... now I have no hyper flash... wierd, do I still need to install new swithch?
Old Jun 24, 2012 | 12:33 PM
o_sobad_3's Avatar
o_sobad_3
has anyone had any issues with noise coming through there stereo when appying there brakes or turn signals after installing led tails? Wondering if load resistors would cure the problem?
Old Jun 24, 2012 | 02:00 PM
Vettmann17's Avatar
Vettmann17
I pretty sure the LED halo tails (I'm assuming those are the ones you have) have resistors built in and you don't need additional ones. As long as the blink rate is normal leave it alone.
Old Jun 24, 2012 | 02:28 PM
mikecampi's Avatar
mikecampi
Thanks for the info guys....
To LED Blinker/Flasher Install
