drive shaft vibrations
Old Jun 28, 2012 | 01:14 AM
fatbillybob's Avatar
fatbillybob
Default drive shaft vibrations
Gents,
Give me some ideas on how to diagnose drive shaft vibrations inside the torque tube besides a teardown and critical inspection.
Thanks!
Old Jun 28, 2012 | 04:40 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Originally Posted by fatbillybob
Gents,
Thanks!
Depressing the clutch pedal decouples the propeller shaft from the clutch assembly. If you experience vibration while reving the engine under this condition, the source of the vibration is most likely as a result of an imbalance in the pressure plate and or flywheel. Additionally, depressing the clutch pedal loads the clutch release bearing and allows the pilot shaft to rotate within the pilot bearing.
Releasing the clutch pedal couples the propeller shaft to the clutch. If the drive line was not vibrating under the previous conditions and is now vibrating the imbalance is most likely in the propeller shaft. Depending on the nature of the imbalance in the propeller shaft, it may not vibrate as much while reving it in neutral since it's not under a load.
Old Jun 28, 2012 | 07:02 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
let us know if this is not the vibrations you are experiencing. I went through this ordeal for a long time and found out I had a bent rim causeing it.
Old Jun 28, 2012 | 11:46 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats ONE OF THE BEST explanations on this issue that Ive see in a long long while!
Bill
Old Jun 28, 2012 | 12:13 PM
RonSSNova's Avatar
RonSSNova
Unless it is a A4, in which case the driveshaft is always coupled to the engine.
ron
Old Jun 29, 2012 | 08:04 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Bill
To drive shaft vibrations
