parasitic drain aftermath
Old Jun 28, 2012 | 12:05 PM
drehi's Avatar
drehi
6th Gear
Default parasitic drain aftermath
I have a 2001 Corvette - had parasitic drain -tested drain using Bill Curlee method - removed 1 fuse at a time - no change in drain - removed all fuses and C.Bs - no change in drain - disconnected starter - no more drain - replaced starter - connected starter wires as disconnected - all fuses and C.B.s reinstalled as removed - no drain on battery - tried to start car - starter works great - BUT car wont start -tried to wake up BCM (removal and reinstallation of fuse #25)- checked DTC codes - no new codes (only history types)
I would greatly appreciate any ideas on a fix.
Thanks in advance
drehi
Old Jun 28, 2012 | 12:07 PM
Corvette_Ed's Avatar
Corvette_Ed
This might be a stupid question, but did you check the battery to see if it still has sufficient charge?
Old Jun 28, 2012 | 12:13 PM
drehi's Avatar
drehi
6th Gear
additional info
2001 coupe - automatic
Battery is new - fully charged
starter cranks engine great
Old Jun 28, 2012 | 12:46 PM
lionelhutz's Avatar
lionelhutz
What is a C.B. in the context you used? The relays?
Did any of the modules show as "no comms" when you checked the codes?
Does the fuel pump run?
Did you check to see if the engine has spark?
Did you double and triple check that you got all the fuses and relays back into their correct locations?
The BCM must be working to allow the starter to engage, otherwise the security relay would not engage the starter.
Old Jun 29, 2012 | 03:59 PM
drehi's Avatar
drehi
6th Gear
no modules show as "no comms"
no fuel
no spark
I took pictures of fuse boxes before I removed the electrical devices - I have checked and rechecked the reinstallation of the fuses and C.Bs and relays.
Alarm horn blows - I think that the anti-theft system is on - I have tried resetting the anti-theft system as recommended by a number of sources - key on wait 10 minutes - key on /crank for 2 seconds/wait 10-12 minutes/try again (3 times) - no luck
I think the BCM is working as all other functions seem to work.
dazed and confused
ehi
(C.B. is an abbrevation for circuit breaker) sorry I should have spelled it out
Old Jun 29, 2012 | 04:02 PM
lucky131969's Avatar
lucky131969
no fuel
no spark
dazed and confused
ehi
How do you know the engine is not getting fuel? Did you take a reading at the rail? Does the fuel pump run?
Old Jun 29, 2012 | 04:20 PM
Corvette_Ed
Have you tried a different key? Your key might be worn enough that it's not triggering the password function properly. I recently had to change keys for this reason and mine was doing the same thing you describe above.
Old Jun 29, 2012 | 04:23 PM
lucky131969
If the key was not being read by the lock cylinder, the engine would not crank.
lucky131969
no fuel
no spark
dazed and confused
ehi
PM Sent.
Old Jun 29, 2012 | 04:28 PM
Corvette_Ed
Didn't see that it said that. Been working on a 16 page paper since 6 AM. Eyes are a little tired.
To parasitic drain aftermath
