Strange reading on volts, need help
Old Jul 5, 2012 | 06:07 PM
Ghost Vette's Avatar
Ghost Vette
Default Strange reading on volts, need help
I have notice within the pass month the reading on on the DIC and the gauge reads 12.3 to 13.0 after dirving a while. So I checked across the battery while engine was running and got 13.8 to 14.2 amd also the same coming from the alternator. I removed the ignition switch and cleaned the contacts which did not help. I can't understand why the DIC reads lower than the reading on the battery and the alternator. Has anyone have this happen before? If so how did you fix? Maybe I shoould just ignore the DIC as long as battery and alternator is putting out ok.
Bob
Old Jul 5, 2012 | 06:10 PM
Lothar34's Avatar
Lothar34
It always reads lower than the battery. That's normal.
Old Jul 5, 2012 | 06:18 PM
Ghost Vette
Thank for reply. Maybe with the 100+ heat, I,m just a little paranoid.
Old Jul 5, 2012 | 09:50 PM
Ghost Vette
Well I just finished pulling the ignition switch and cleaned the contact. They didn't look bad to start with. Got it back together and didn't seem to help much with the voltage. I have also check the grounds to make sure they were clean and tight. Not really sure where to go from here.
Old Jul 5, 2012 | 09:54 PM
Dave68's Avatar
Dave68
My Mazda does the same. I have a digital voltage meter that plugs into the cigarrete lighter and lately, since outside temps have risen, the voltage meter has been about half a volt lower. It is okay in the morning when it is cooler. Voltage at the battery is similar to yours while the car is running.
Old Jul 5, 2012 | 10:24 PM
Ghost Vette
Really difficult to find the cause and I hate electrical problems. I'm not good at dealing with them. Let me know if you figure it out.
Old Jul 6, 2012 | 12:22 AM
tds69tx's Avatar
tds69tx
Default ???
Bob
Bob---
I've had the same problem since 99--- lots of questions and research and no answers ---maybe someone will step forward.
Terry
Old Jul 6, 2012 | 10:10 AM
OkieBikerDude's Avatar
OkieBikerDude
I agree, Summer time is especially hard on electrics and batteries. I have occasionally observed the same thing. When on the road and everything seems to be fine, the DIC shows around 13.7 to 14.1 volts. Since this is showing the output from the alternator, I'm not concerned. If I stop at a light or for some reason and leave the engine idling, the indicated voltage drops to slightly less than 13 volts. I believe this is caused by the second fan coming on and what I see is the lag time before the alternator starts to make up the difference.
This isn't a scientific observation but I've seen it for a couple of years now and it is a reason I continue to monitor the voltage. I've also cleaned the ground connections near the alternator due to earlier EBCM problems. Since repaired.
Good luck and if you discover a cause, please let us know.
OBD
Old Jul 6, 2012 | 12:51 PM
Ghost Vette
Thanks everybody for your input. Maybe I'm just overly concerned.
Old Jul 6, 2012 | 03:01 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I remember a post from Bill Curlee that there's a ground on the frame down low between the battery and fuse box, that can cause the voltage reading to be wrong. He's got a picture of this ground nut somewhere here in the forum.
Old Jul 6, 2012 | 08:51 PM
Ghost Vette
Thanks, I am going to search and see what I and find. Bill has been a big help to me in the pass. Maybe he has the answer this time as well,
Bob
To Strange reading on volts, need help
