Window Problem
Old Jul 7, 2012 | 07:17 PM
nsurdi's Avatar
nsurdi
4th Gear
Default Window Problem
Have a 2000 convertible. Replaced battery now driver's side window will not go up or down. I checked codes and B2204 for left window switch fault came up. Could it be a fuse or something else?
Old Jul 7, 2012 | 10:58 PM
nsurdi's Avatar
nsurdi
4th Gear
Thanks I will try that tomorrow.
Old Jul 8, 2012 | 10:14 PM
nsurdi's Avatar
nsurdi
4th Gear
#33 fuse was good and I cleared the DTC but the driver's window still is not working. I can hear a slight clicking when I press the switch. Any other suggestions would be appreciated.
Old Jul 9, 2012 | 05:15 PM
Dave68's Avatar
Dave68
http://forums.corvetteforum.com/c5-t...de-window.html
Old Jul 9, 2012 | 07:57 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Window regulator easy to change out. If you put up your windows up and down regularter.on c5,s it called use or loose/ you can try one trick take out the handle door plug. Ingnition on have have somebody hit the torx srews and hammer light and do the windoow switch up and down. And the window might work. Two people works best// and if it works do it up /and down for days too clear the armature on the motor. Joe
Old Jul 9, 2012 | 11:34 PM
nsurdi's Avatar
nsurdi
4th Gear
Thank you I will give it a try.
To Window Problem
