DIC read " Charge System Fault "????
Old May 27, 2002 | 02:31 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default DIC read " Charge System Fault "????
I was driving with the Air Conditioning on yesterday when i noticed that the air coming out of my vents was warm ..So i turned the AC off and then turned it on again , thats when my DIC read " Charge System Fault " and my AC would not turn on .
I waited a while and tried it again and it worked.
Any other members experience this problem ? It seems to be working fine now , but i think i trip to the dealer might be a good idea.
I'd hate to have AC problems on my next trip to the Desert.
:cheers:
Jeff
Old May 27, 2002 | 02:35 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: DIC read " Charge System Fault "???? (BLUTHUNDER)
I have had that happen every now and then...just think it happens for some reason if the alternator isn't putting out enough juice for a second.....not sure though...
Old May 28, 2002 | 04:07 AM
Hex29A's Avatar
Hex29A
Default Re: DIC read " Charge System Fault "???? (pewter99)
PEWTER99,
Do you have an UnderDrive pullie also? From BLUTHUNDER signature, I notice that his has one.
BLUTHUNDER,
Are you driving the A/C -10% all other -15% with the UnderDrive pullie? I am wondering if that is the problem.
[Modified by Hex29A, 3:10 AM 5/28/2002]
Old May 28, 2002 | 10:43 AM
pewter99's Avatar
pewter99
Default Re: DIC read " Charge System Fault "???? (Hex29A)
No I don't have an underdrive pulley. In the past when this happened I had it checked out and nothing was found wrong...it seems when I get the problem is just after I start up or if I get off the clutch wrong and the engine stumbles slightly, thus rpms drop but engine running and it causes this code/display on the DIC...
Old May 28, 2002 | 10:55 AM
BLUTHUNDER's Avatar
BLUTHUNDER
Hex29 , yes i have had the underpully changed... Pewter99 , thanks for the input.
I guess i will leave it for now , i also have a 1300 Fosgate AMP installed ..So maybe thats drawing some extra amperage.
:cheers:
Jeff
Old May 28, 2002 | 11:00 AM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
I get this msg too every now and so often. I replaced my battery with optima red top - didn't make any difference.
Old May 28, 2002 | 11:08 AM
Geckoman's Avatar
Geckoman
[QUOTE]
Any other members experience this problem ? It seems to be working fine now , but i think i trip to the dealer might be a good idea.[QUOTE]
Seems to me a forum member posted a few months ago to have the negative battery cables checked... the dealer replaced it and this solved their problem. I have had this problem occasionally when starting the car-- goes away after a second or two.
Old May 28, 2002 | 11:24 AM
TedH's Avatar
TedH
I get that message about once a week recently on my 2001. The car runs fine and I suspect nothing is seriously wrong.
Old May 28, 2002 | 07:34 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I had it occur once while slowly backing out of the driveway - never saw it again. I just assumed that it was an engine stumble of some kind. Never had an issue with another system (ala the a/c) not working (that I know of).
To DIC read " Charge System Fault "????
