Codes - cruise control - assistance, plz
Take a look at these links taken from this thread http://forums.corvetteforum.com/c5-t...ack-again.html:
diagnosis
http://forums.corvetteforum.com/1568186703-post64.html
removal
http://forums.corvetteforum.com/1571067145-post107.html
repair procedure
http://forums.corvetteforum.com/c5-t...ch-repair.html
To summarize:
A/c blows hot, passenger side, no codes showing
right rear tire is low, no codes showing.
Cruise control stopped working, no codes showing.
Codes:
Ldcm (4 codes), 2282h, 2284h, 1064h and 1016h.
Rdcm (4 codes), 2283h, 2285h, 1064h and 1016h.
Rfa (3 codes), 1096h, 1064h, and 1016h.
No current codes w/engine running or not running, and all other modules returned no codes whatsover.
BC
One step at a time for sure.
In regards to your original post in regards to the cruise control....
Here is a picture of where it lives.
Disregard the different looking adjustable clutch master cylinder arm,
( adjustable, Tick unit)
The switch is shown in the upper left corner of picture.
White in color with adjustable stub against the clutch pedal flat tab.
If the switch is pushed in as in the photo, (making contact) then that isn't the problem.
If it isn't pushed up & making contact, It screws in & out for adjustment.
The picture shown is with the c/control stub in contact, & in it's proper position, thanks & compliments to member Corvette Chris, for the picture.
I understand that it is in a hard to get to location.
Taking the drivers seat isn't much of a job, & would make getting into this area much easier.
http://forums.corvetteforum.com//1579381203-post64.html
Thanx much,
fred.
