Battery Died
Hooked jumper cables to it and it fired right up. The gauge was reading 13-13.5 volts while the car was running. That told me the alt was charging.
The car has an AC Delco 78-6yr battery in it. The car is an 02 with 36,000 miles.
Question is this the stock battery?
2nd question do I put another AC Delco in or Optima red or Optima Yellow?
Give me some advice on what to buy.
Just went out and decoded the AC Delco It was Febuary 2005. So it wasn't the original but it lasted 7 years. Most batteries now only live 3 years. So I'd say the first owner got his "monies worth".
A standard high quality lead acid battery will do you fine. Oh,, by the way,,, the OPTIMA is a lead acid battery. The cells are just wound in a spiral instead of standard flat plates .I Was in AutoZone at the checkout counter and almost dropped a load when I saw that the Red Tops were $199
When I purchased mine back in 2004, it was $102.I just purchased the Duralast Premium battery for my 02 Z and couldn’t be happier! Just get a battery with a high reserve capacity and you will be all set.
It’s a DIRECT DROP IN, no hassle, works fine lasts a long time battery and it didn’t break the bank.
BC
I would consider the suggested Sears battery, but I put 3 of them in my Motor Home 2 years ago...2 of the 3 are kaput...
Looking for other suggestions...
I see absolutely no advantage to the Yellow Top Optima unless you are regularly discharging the battery by listening to the stereo etc with the motor off.
I have had Walmart batteries in all my cars and trucks...no problems that I didn't cause myself(turned the interior lights on with the dash dimmer switch, and FORGOT it)
They replaced them FREE...everytime!
They are U.S. made batteries from Wisconsin (I think?)
Sounds like an oxymoron!
I use Diehards and have no complaints. I also use a battery tender if it's going to be a couple of weeks or more between outings
