Need alignment advice
Old Jul 16, 2012 | 10:01 PM
19vette91's Avatar
19vette91
Default Need alignment advice
My 2002 zo6 actual rear alignment numbers were 0.13" left and 0.19" right when recently checked. If nothing is done will these #'s cause the extreme inside of the rear tires to wear alot more than the rest of the tire???
Thanks, you guys here on the Forum are GREAT for helping other members who don't have technical experience.
Old Jul 16, 2012 | 11:46 PM
m6 c5's Avatar
m6 c5
If you are referring to camber then no it wont as you have to have negative numbers to wear the inside edge first. Those numbers would cause the outside edge to wear a little faster.
Old Jul 16, 2012 | 11:55 PM
19vette91's Avatar
19vette91
Thanks, but i was referring to rear toe with those #'s. Would that cause the excessive inner wear I experienced??
My rear camber was -0.85 left and -.61 right.
I have very excessive inner wear on the 1/8 inside tire on both sides
Old Jul 16, 2012 | 11:57 PM
m6 c5's Avatar
m6 c5
I dont think it would, too much toe in or toe out will cause excessive tire wear but I am pretty positive it depends on the camber as to whether its on the inside or not.
Old Jul 17, 2012 | 12:06 AM
19vette91's Avatar
19vette91
the extreme inner right tire side is down to the white treads while the center and outside is half way to the tread wear bar???
pretty much the same on the left tire, but tread wear not as bad.
Old Jul 17, 2012 | 07:18 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
In my humble opinion, the combination of a little too much negative camber, and a little too much toe, is causing your problem.
I seem to recall that the factory spec for rear camber is -.02*, and the toe setting is something like .01* toe out....
Old Jul 17, 2012 | 12:31 PM
m6 c5's Avatar
m6 c5
Im going to have to agree with that statement.
It sounds like you need to get new tires but before you do get it aligned to spec first.
Old Jul 17, 2012 | 01:06 PM
lionelhutz's Avatar
lionelhutz
I'd have to agree with the others, too much camber and too much toe to get good tire even tire wear.
My alignment is -0.4* camber all the way around with 0.1* toe in on each front wheel and 0.1* toe out on each rear wheel (0.2* total toe on each end). I do lots of highway driving and I'm getting great tire wear and it drives nice too. My rear PS2's hit the wear bars on the inner tread at 40k miles with just slightly deeper tread on the outside.
Others (some aftermarket and performance shops) will tell you to use toe in on the rear, if you decide to try that then use 0.1* toe in on the rear instead of the toe out.
Talk to the shop and agree on the exact numbers you want. Don't just let the shop set the alignment "within spec" because there is a large variance allowed in the stock specifications. For example, within stock spec allows one rear wheel to toe in and the other to toe out. Not getting the settings equal side to side can really mess with the handling and you won't be happy how it drives. The only variance should be a little more caster in the right front (somewhere around 0.5* to 1*) to compensate for road crown.
Old Jul 18, 2012 | 09:24 AM
AU N EGL's Avatar
AU N EGL
Get the alignment guys to make it exact, not within a range.
Old Jul 18, 2012 | 02:41 PM
leadfoot4's Avatar
leadfoot4
That's it in a nutshell..... If you're not sure what "numbers" you want, simply go with the "nominal", or dead center, of the "acceptable range"...
To Need alignment advice
