01 z06 clutch fluid gone
Either way this sucks I just got the car barely drove it and I can't drive it now. Texted the car lot guy I got the car from told him it's ****ed up, will call in the morning to see if they will fix it or take it back.
Looks like it may be coming from a line in there but no idea. The picture is god awful, my phone focuses on other **** then deep in there..
This is a crappy way to start your experience with this car, hopefully you can resolve it easily and without cost
That is a good price for all the work that is involved, for a little over $100. part.
Without starting a new thread i got another question, below my key on the dash there's a square piece that's missing and a hole where it looks like something should be, can't take a pic until i get car back. Any idea wth it is and where i gotta go to get a replacement thingy.
Then gotta find the little dials for bass fade and whatnot prolly ebay when i get off work
You did nothing wrong for the slave to go out.
They eventually just wear out.
The sqare piece that you are missing is the air temp sensor, cover
It's this piece here.
http://www.ebay.com/itm/97-04-CORVET...-/260589755614
Only reason I ask is because, some of you may not like this lol, I am learning how to drive a stick with my z06. Been 4 years since I drove one and only a few times when I did, like maybe 5 times. But they said the hose ruptured that is connected to the slave. Guess I got really lucky it did it immediately after buying the car then eh?
Do you know if you have an after market remote clutch bleeder installed?
That was probably the culprit.
From your picture you posted up, it was quite blurry.
In regards to that air temp sensor cover try getting hold of...
Mark Rose 615 896 6100
MarkAVettenuts.net
http://www.Vettenuts.net
Yea the picture sucked, it was dark and my phone decided to focus in on the wrong ****!
The answer is still no.
As mentioned before, things wear out, which in most likelyhood is the case with yours.
You bought the car used.
You or anyone else here on the forum, know if or how parts were replaced prior to your purchase.
If the slave had been replaced in the past(more than likely has) & the slaves line was not reattached out of the way from hot parts, or
from rubbing a wear spot through the line against something.
To prevent any heat or premature rubbing/ wear, it's best to have a heat a sleeve on the hydraulic line/lines.
The disconnect from the clutch slave to clutch master cylinder could possibly became disconnected.
You didn't know if you have an aftermarket bleeder line.
Did you find out?
These sometimes leak.
Do you have headers?
Sometimes lines get up against hot pipes & melt/leak.
Heat sleeve over the line/lines will/would prevent melting/wearing.
Most times when slaves wear out & leak, they leak right at the slave unit itself.
The leak will show up dripping out of the bottom of the bell housings inspection plate "weep hole"
It would be wise for you to keep an eye on the parts for sale/wanted section, here on the forum.
The 3 book service manuals can be picked up for reasonable pricing.
There are volumes of information & diagrams in there.
