My C5 LS3 Build
I was able to land a super low mileage L92 short block (same block casting and internals as an LS3 with the exception that the pistons have 2cc valve reliefs). I then got hold of a new LS3 top end, new intake from a friend and new heads from GMPP. A Ligenfelter converter box should allow me to run the LS3 without swapping the cam sensors and crank reluctor wheel.
Here's a list of whats going into this motor so far:
GMPP LS3 heads
LS3 intake w/90mm throttle body
PRC .675 valve springs
Stock rockers
L92 block, DOD delete
Ported and shimmed GM LS6 oil pump
TSP 231/236 .641"/.615" 114lsa cam
TSP 1 3/4 headers
Short x-pipe with two Dynomax bullet mufflers dumping under car
3600 SS Yank
Built 4L65E w/3.42's
LPE 24x58 tooth converter box
Knock sensor extension
MAP sensor extension
Getting started
Clean bottom end. Really low miles
Cam is in. New timing set and oil pump too
New GMPP LS3 heads. Love the huge intake valves.
Installing PRC EHT .675 valve springs
She's ready for the transplant
A little preview. I'll bolt the heads on once the motor is in the car. (yes the vlv cover is backwards. Lol)
Pics of the holes in lifter trays.
http://media.photobucket.com/image/l...d/P1020753.jpg
Headers got a new coat of high heat ceramic paint. Rustoleum 2000, great stuff.
Just wanted to share this..I dont know if this guy is here on CorvetteForum but this is a great example of the potential for an LS3. Cam only with bolt-ons, 517rwhp/462rwtq! 10.76@129. His cam is very close to mine. This got me really excited and looking forward to some 1/4mi times.
http://ls1tech.com/forums/dynamomete...24-timing.html
