LG Header install ?
At the moment the headers are just snugged to the heads with just a few more turns left to tighten but, I don't see them being pulled in away from the shield.
I could pry them off and tighten the bell housing mount to maybe hold them but, would I be putting too much strain on the head bolts or should I go ahead and torque the head bolts then do the prying?
I, initially, thought those tabs near the collectors bolted up to the bellhousing mount but when I saw how far off they were, I figured the extra bar they included with the headers was supposed to be used as I could find no instructions for the "Street" header install.
Anyone else installed some of these lately that could clue me in on how to proceed?
Sonny
You show an arrow on both headers/h/shield junctions.
So evidently your against the shields on both sides?
If that is the case & you are saying that if you were to try & completely tighten down the headers at the heads, things would get real tightat the heads location & the shield location.
I would give LG a call.
While on the line with the tech person, have them come on to the CF site & take a look at the visual you have posted up.
Hopefully they will have an answer with this issue.
By the way. it looks as though those two lines are touching that sheet metal cross bar at the bell.
If you plan on keeping that bar in place, you may want to split a short lenth of fuel line hose & slide in between the two, to act as a buffer.
I would be careful prying (if I had to pry) because you could crack one of the welds on the headers.
Last but not least if your real unhappy call LG and ask them where the headers should line up in relation to the heat shields. If any of the tolerances are real close to touching any part of the car, once the car saturates with heat after driving you will hear them rattle against the car (especially if your running a cam (when it lopes)).
I'm just having a hard time picturing how the x-pipe, mid pipe and cats with all those junctions are going to hold the headers in position once I tighten the headers to the heads but, I'm willing to give it a try the next time I get out there.
I just thought there maybe someone on here that experienced the same thing that might be able to shed some light on how it's done as I have always heard how easy these systems are to install and was wondering what I was doing wrong.
Thanks for the replies,
Sonny
Makes sense to me.
You may be fighting that bracket you have attached to the bell.
I have the instructions from LG that I used back in 04, when I installed their
Pro LT's.
Pertaining to what you are having problems with.
"Do not tighten the bolts to the flange all the way until you get the bell housing bolts started.
Once they are started, then you can tighten the exhaust flange on the engine."
That bracket was loose in the pics. Just there to hold up the collector 'till I got the head bolts in place (I'm working alone). It is not holding them apart.
Sonny
Gene
Start the bell housing bolts (loose)
Tighten down the header flange bolts.
Tighten down each section there after, all the way back to the mufflers.
After the the engine has been run, all bolts & clamps should be
re tightened.
May help to tap the pipes to vibrate the system to get the clamps totally tight.
As per LG Instructions
If you don't then here they are: C5 Pro Long Tube installation
Thanks anyway,
Sonny
So, I have a plan! Now, it's out to cuss some clamps!
Sonny
