LG Header install ?
Old Jul 24, 2012 | 12:03 AM
moespeeds's Avatar
moespeeds
How about you flatten that heat shield a bit with a ball peen hammer.
Old Mar 26, 2013 | 09:38 PM
Racer Z06's Avatar
Racer Z06
So what did you find out? I am installing mine and have the same questions
Old Mar 26, 2013 | 11:19 PM
bumble-z's Avatar
bumble-z
Go with the procedure in post #19 & you will be all right.
Old Mar 27, 2013 | 10:00 AM
sbulla's Avatar
sbulla
Sorry, I didn't notice that this old thread had been dug up but, after a few thousand miles of running the headers, I still occasionally check the fit of the headers along with leak checks and, the pass side collector will stay off the shield with no help from the bellhousing bracket but, the drivers side will still spring over to within a 16th of an inch or less of the shield if I loosen the bracket so, I keep that side cinched down to prevent contact.
If, for any reason, I ever remove the header, I would probably remove that rivet that holds the shield on the drivers side and flatten it out to give me the clearance I would feel comfortable with.
As it sits right now, I'm using the bracket to hold the driver side collector off of the shield about an 1/8 of an inch so, hopefully, the tab on the header will hold up to the little bit of strain put on it. So far, so good.
Sonny
Old Mar 27, 2013 | 10:34 AM
Racer Z06's Avatar
Racer Z06
Thanks for the info. I am amazed and disappointed that LG motorsports doesnt include detailed instructions for these headers, or the header gaskets, or all the hardware required for the bracket.
Old Mar 27, 2013 | 01:15 PM
sbulla's Avatar
sbulla
Header gaskets were included with my kit. They use a different set from stock with the rounder opening. I think I heard they are from a Camaro.
You might check with them on that.
Sonny
Old Mar 27, 2013 | 01:42 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Almost all of our instructions are moving online for easy access. For both current customers and those looking to purchase. Not everything is up yet but we are loading them weekly.
http://www.lgmotorsports.com/gallery...s.php?album=23
Only the Street Series do not come with gaskets, all Pro systems do.
Not sure which bracket you are speaking of, if you are talking about the Street Series on the C5 cars, that should not be included with the kit, but some of them still have it in there. We found that by having that installed it could lead to the bracket tab on the header to crack and fail.
Old Mar 27, 2013 | 05:23 PM
sbulla's Avatar
sbulla
I guess I must have ordered the gaskets separately then. If I remember correctly, they came in the same box though.
Sonny
Old Mar 27, 2013 | 09:12 PM
Racer Z06's Avatar
Racer Z06
I have the street series and thats the bracket there with the bolts in it. So should I run the bracket or not I have read 12 different answers even from you guys. Can you email me the instructions for the STREET series? I will pm you my email because flying blind is no fun.
Old Mar 30, 2013 | 12:28 PM
Racer Z06's Avatar
Racer Z06
Luckily mine didn't hit the shields. I have always loved these headers....but leaving people in the dark on the install....
Old Apr 19, 2019 | 01:12 AM
Blk97c5tx's Avatar
Blk97c5tx
1st Gear
Default Still no instructions LG street headers
I just purchased and received a set of the street headers from LG and they didn’t come with any instructions. I emailed them for instructions or directions and still have not recorded an answer....
