Rear Diff Break-In
Old Jul 21, 2012 | 08:37 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default Rear Diff Break-In
Hello,
I searched the forums and I am still not clear. It is a 3.90 Quaife from RPM. They states 3 heat cycles consistin of driving for 30 minutes at varying speed. They said then it is ready to go. They said I do not even have to change the oil. The not chnaging the oil really concerns me.
I would appreciate any help.
Old Jul 21, 2012 | 09:35 PM
craig04c5's Avatar
craig04c5
When I got my 4:10's new from DTE they said to drive under 50 mph and keep rpms under 3K for 500 miles then change the fluid. No sudden take offs. Most differential builders recommend similar same break-in procedures.
Old Jul 22, 2012 | 07:08 PM
123sugey's Avatar
123sugey
Dig
Listen to the manufacturer's recommendations.
Old Jul 22, 2012 | 09:40 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
You should be doing some figure 8's in parking lots too to break in the oil into the rear end clutch packs. I heard not doing this will cause rear end gear whine.... Just what I heard. When I changed the fluid in my rear end I did multiple figure 8's to get the fluids into the rear end clutch packs. No issues with gear whine here.
Verify with the manufacturer also.
Toque
Old Jul 23, 2012 | 12:02 AM
_r2h's Avatar
_r2h
Toque
It's a Quaife. No clutch packs.
Old Jul 23, 2012 | 05:20 AM
vettenuts's Avatar
vettenuts
I did the same with my DTE. Their instructions and warranty were very specific to break-in.
To Rear Diff Break-In
