transmission slop / clunk
Here is something that you can do that will give you the creeps.
If you have a MN6/MN12, start the engine. Put the trans in neutral, let out the clutch and turn OFF the ignition. Listen to the drivetrain!!!
Its perfectly normal by the way!!
That’s the lost motion in the clutch, torque tube and tranny making noise as the engine coast down to a stop.
If you press in the clutch, it will not make that noise..Bill
See my post here:
http://forums.corvetteforum.com/c5-t...-for-a-c5.html
See my post here:
