engine coolant question
Old May 28, 2002 | 09:39 PM
70 LS1's Avatar
70 LS1
Default engine coolant question
Is there a reason that GM says to run the dexcool coolant instead of the green glycol coolant? Is there a problem with running the glycol?
thanks
Old May 28, 2002 | 09:49 PM
wwashing's Avatar
wwashing
Default Re: engine coolant question (70 LS1)
thanks
Actually both are ethyl-glycol based. The difference is in the corrosion inhibitors. The Green stuff looses effectiveness over time, and this is death to your aluminum block with is highly suseptible to corrosion to the point of being eaten away by it,
The Dexcool has organic based inhibitors which last virtually forever, thus preventing any corosion ever starting in your aluminum.
Only use Dexcool.
Old May 28, 2002 | 09:54 PM
70 LS1's Avatar
70 LS1
Default Re: engine coolant question (wwashing)
DAMN!
I used the green stuff when I filled the radiator the other day. Should I drain, flush and refill right away, or can I let it go for a little while?
Old May 29, 2002 | 12:04 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
DAMN!
no problem adding the "green" stuff, you just need to change your coolant at a more frequent interval. I believe the stock dexcool is good for five years, and if you add the "green" stuff you must change it alot sooner, but no damage will occur.
Old May 29, 2002 | 12:21 AM
pkmoose's Avatar
pkmoose
Category: Coolants
Bulletin No. 01.010
Date: 01/12/01
Replaces: 96.009
Introduction:
Equilon (owned by Texaco® and Shell®) markets a European coolant technology (OAT) that consists of ethylene glycol inhibited with a combination of sebacic acid and 2-ethylhexanoic acid supplemented with tolyltriazole. It was originally called "Long Life", but a lawsuit brought by Warren Oil, who markets a fully formulated coolant under the brand name "LongLife®) forced the retraction of that term form the DEXCOOL, Texaco and Caterpillar® packaging. The combination of a mono and dibasic carboxylic acids permitted Texaco to obtain a patent on the specific combination. Other companies have obtained similar patents, by varying the mixture somewhat and by using similar, but not exactly the same, chemistry.
General Motors® has been using this coolant technology in their cars and light trucks since the start-of-production of the 1996 model year vehicles (except Saturn®, which began in 1997). GMC® medium trucks equipped with Caterpillar engines, have been getting a nitrite-added form of DEXCOOL (NOAT) to insure protection against wet sleeve liner cavitation-erosion.
Frequently Asked Questions:
Can DEXCOOL organic acid antifreeze be mixed with ethylene glycol antifreeze?
It is ethylene glycol based antifreeze! The concern with mixing comes from the fact that there are very different chemical inhibitor packages in use. Most leading technologies will work very well when used as intended, typically at 50% in good quality water. If the coolants become mixed with DEXCOOL, however, one study showed a possible aluminum corrosion problem in certain situations. The other question is a concern for dilution of the protection packages. At what mix is the there too little of either inhibitor to protect the engine? As a precaution, both GM and Caterpillar instruct that contaminated systems must be maintained as if they contained only conventional coolant.
How long will it last?
Uncontaminated, the engine manufacturers instruct that it may be kept in service for 5 years or 150,000 miles in cars. In trucks, Caterpillar and GM currently recommend that the nitrited version of the coolant be run 300,000 miles or 2 years, re-inhibited with a nitrite-tolyltriazole "extender", and run to a total of 600,000 miles.
Are there different brands that meet the spec?
Yes. Any brand displaying the DEXCOOL trademark meet the spec, others advertising compatibility are from the same family of coolants.
How can a customer tell if he has DEXCOOL?
If the customer owns a GM car and has orange coolant, then its DEXCOOL! In GM trucks the coolant is "orange- red", indicating that it contains nitrite. Orange coolant in Daimler-Chrysler® vehicles is NOT Dexcool. (Daimler Chrysler owners with orange color factory coolant should consult their owners' handbooks).
Does it protect aluminum?
Yes, even though it contains no silicate, the primary aluminum protector in conventional antifreezes, published data shows that it protects aluminum.
What are the advantages of DEXCOOL compared to the previous GM 6043 factory-fill?
Compared to old-fashioned phosphated antifreeze, it may be more stable and improve water pump life. Evaluations of the two technologies to compare their respective service lives has found them comparable. In fact, a Ford Motor Company study concluded that organic acid coolants do not offer any significant advantages for the consumer over current North American coolants. In a modern car with a well maintained cooling system, current North American and OEM factory fill coolant corrosion protection can be extended far beyond previous expectations."1
What are the disadvantages?
Higher cost, possible incompatibility, limited availability.
Is it environmentally safe?
It is ethylene glycol based. It is toxic. While it does reduce coolant waste, it is not environmentally safer than conventional EG coolant.
How can you test it?
Use a refractometer to test the freeze point. The inhibitor levels can not be cost effectively tested. If in doubt, throw it out and start over.
Should we recommend that Pencool® 2000 or Pencool 3000 be used with Dexcool?
Penray does not recommend the use of Pencool in Dexcool coolant.
Pencool® is a registered trademark of The Penray Companies, Inc. Dexcool® is a registered trademark of GM.
http://www.penray.com/bulletins/dexcool.htm
Old May 29, 2002 | 06:18 PM
thehub's Avatar
thehub
Go to your local NAPA or ??? parts store and get Havoline (Dex Cool). The only
difference between GM's and Havoline is the cost. Havoline makes the Dex Cool
for GM. Just an FYI...............
Dave H
Old May 29, 2002 | 09:45 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
"If the coolants become mixed with DEXCOOL, however, one study showed a possible aluminum corrosion problem in certain situations."
After rebuilding the motor on my '71 and having my radiator recored, I trotted over to the local NAPA for the Havoline Dexcool material. The manager advised me that I should replace all my hoses and the heater core also, as it wasn't a good idea to risk contaminating the Dexcool material with the "green stuff" - in other words, he didn't want to sell it to me, and I didn't buy it. I don't know how critical the warning quoted above is, nor do I know the quantities they are referring to when they say "mixed". A quart of green in the system? A gallon? 50/50? Two drops? I think it would be worth digging into this a little more, and maybe someone else has the answer as to how much "green stuff" is too much for the Dexcool to not be affected. Once you use green, can you not go back??? :confused:
Old May 29, 2002 | 10:41 PM
vettenuts's Avatar
vettenuts
Default Re: engine coolant question (BSiegPaint)
You need to go to the source on this. There is much mis-information on DEXCOOL. You can mix them, but Texaco doesn't recommend over 10% green to DEXCOOL. You won't get the extended life either. Additionally, if you have been running the green stuff with silicates, you may never get the extended drain capability because the entire internals are already coated with silicates.
I switched all of my cars over from the green a few years back. You must keep the system full and you must use a cap with a spring center drainback feature. If my car came with DEXCOOL, I would stay with it. $5.98 at Wal Mart by the way.
To engine coolant question
