A/C Help
Old Jul 28, 2012 | 01:45 PM
bluesjunkiex's Avatar
bluesjunkiex
7th Gear
Default A/C Help
Hi I'm new here and would like some help if possible the first thing is my A/C was blowing warm on the driver side and cool on the passenger side so i had it checked and charged and it was cool for about a hour and now its warm on both side and now the the A/C light will not stay on and i had a problem with the turn signal sometimes not working until i hit the hazard button on and off and the lighter doesn't work not sure if this is all connected to the same problem Thanks
Old Jul 28, 2012 | 01:55 PM
Corvette_Ed's Avatar
Corvette_Ed
You'll need to pull and post your DIC codes. It sounds like you've got several problems going on.
Old Jul 30, 2012 | 12:18 AM
bluesjunkiex
7th Gear
i found a lot of codes
PO 1718C
PO1748C
C1226H
B2723H
B2252
B2282
B2284
B2262
U1255
U1064
U1016
U1096
B2283
B2285
Old Jul 30, 2012 | 09:09 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Low battery, possible air bridge off the MAF(assuming you posted the two C-codes wrongly), PASS-Key issues and etc...but nothing obvious with the AC. Sounds really like you are low on refrigerant. Clear all of the codes and then check again. Suggest you take the car to a professional AC shop so they can properly check the charge levels. If the other codes come back, start with the battery.
Old Jul 30, 2012 | 02:59 PM
bluesjunkiex
7th Gear
i took it to have check and was told it was low and after it was charged the A/C light will not stay on could that be a safety feature because it may be too pressure on the A/C from the mechanic putting too much refridgerant.
Old Jul 30, 2012 | 03:07 PM
dgrant3830's Avatar
dgrant3830
A professional shop "should" know what they are doing. R134 systems require a specific amount of refrigerant based upon the ambient temperature outside at the time of filling. If they did it right, they would have evacuated all of the refrigerant and pump back back in a specific amount for that system. Too low or too high, it will not work.
Old Jul 30, 2012 | 05:52 PM
bluesjunkiex
7th Gear
i had the 134 with the gauge on it and it said full but i took it to a shop and he said it was low and charged it and then it was cold for about an hour and now the A/C light will not stay on
Old Jul 30, 2012 | 07:46 PM
dgrant3830's Avatar
dgrant3830
Maybe you have a leak then...compressor seals?
Old Aug 12, 2012 | 03:46 PM
bluesjunkiex
7th Gear
any possible reason why the A/C light will not stay on lights up for about a second then out
Old Aug 12, 2012 | 04:27 PM
shadowman1's Avatar
shadowman1
The high side ports are known for leaking especially after putting guages on. Make sure they checked it and if they didn't completly evacuate the system and pull a vacuum before charging the system will not be charged right. You can't top off 134r systems. They should have put dye in with the oil as well.
Old Aug 12, 2012 | 05:54 PM
bluesjunkiex
7th Gear
yaeh they put the dye in and they said it had no leaks and charge the system and it was cold for about an hour then the car sat for a while then only hot air and if you press the A/C switch the light will stay on just for a second then goes out and the A/C will not work
Old Aug 12, 2012 | 10:28 PM
dmarkshark's Avatar
dmarkshark
You need to fill out a profile and maybe someone can help you better. Sounds like you need a to find a more qualified mechanic to look at it. I had to do that to get mine fixed.
Old Aug 13, 2012 | 10:30 AM
waddisme's Avatar
waddisme
Sounds like a leak to me. AC will not stay on once freon leaks out of system. Not good news if the dye is not showing up anywhere visible, especially if leaking that quickly. I had 2 shots of dye, vacuum test, soapy water test and no visible leak. Those are all the symptoms mine has but mine is the evaporator. Big chore to repl so that will have to wait until winter. I hope it is not that. Good luck.
Old Aug 13, 2012 | 11:33 AM
rebelheart's Avatar
rebelheart
Most likely you have a leak.The light will not stay on if the system is low.
Old Aug 14, 2012 | 11:05 AM
bluesjunkiex
7th Gear
thanks I'll take back to the shop that charged it and will update
Old Jan 14, 2013 | 08:55 PM
Fixed's Avatar
Fixed
Any update on this? Mine is does the same thing.
Old Jan 15, 2013 | 08:44 AM
waddisme's Avatar
waddisme
After repl compressor, seals, accumulator, shrader valves, orifice I determined it was the evaporator. I am in the middle now of repl - 15 hr job. However, the evaporator I ordered did not have the seal kit, so I have been waiting since Jan 3 on that. Here is where I am at now:
[IMG][/IMG]
It is not real diffulcult, but it is a lot of work.
Old Jan 15, 2013 | 06:11 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Hey! That looks familiar!
Yea, the job isn't really that bad but it's a LOT of stuff to do. I'd stick in a new heater core as long as you've gone that far. If you think this job is irritating, how do you think going back in would feel?
Mine also was a nightmare, though I know that doesn't make you feel any better.
To A/C Help
