Ignition Switch
Old Jul 31, 2012 | 10:32 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Ignition Switch
Need to replace the electric ignition module....thus need to pull off the key tumbler....any bear traps here??? ....what do I need to watch out for??....electrical part should be "plug and play"
Old Jul 31, 2012 | 10:51 PM
dlind4's Avatar
dlind4
yes it's fairly easy. Just install and your good. There's a tab at the bottom of the lock cylinder you push in to release it. You have to have the key in. Not too difficult.
Old Jul 31, 2012 | 11:19 PM
04blackice's Avatar
04blackice
What issues are you having.wondering if mine is going bad..
Old Aug 1, 2012 | 12:18 AM
REDL98C4's Avatar
REDL98C4
Problems with mine to.. my key only goes in one way and I have to fight to get the key to turn.. Time to replace the key switch??
Old Aug 1, 2012 | 12:22 AM
REDL98C4's Avatar
REDL98C4
You may want to check out.... "C5 Ignition Switch Repair" by Bill Curlee here on the forum. Very helpful post.
Old Aug 1, 2012 | 01:48 AM
04blackice's Avatar
04blackice
My tumbler is fine.but i heard the switch behind it can cause issues with.security light.and ive got abs ane high voltage warning a few times.trying to weed everything out
Old Aug 1, 2012 | 09:08 AM
MStrahan's Avatar
MStrahan
I just installed a new key cylinder and didn't find it too difficult. Once you get the panels off it's pretty straight forward.
i had to replace mine because my key would not go into the cylinder. Luckily I got it in one last time so that I could turn the key to unlock the cylinder.
Good luck.
Old Aug 1, 2012 | 09:13 AM
Irish Whiskey
ABS and Trac.control (yellow) lights come on--A/C won't work ----codes are 1689 and 1571
Old Aug 1, 2012 | 09:16 AM
Irish Whiskey
my tumbler is ok ....just the electronic module is shot behind it and I need to get the metal aluminum switch off to get at it...
To Ignition Switch
