radiator removal
Old Aug 2, 2012 | 12:18 AM
dlind4's Avatar
dlind4
Default radiator removal
I just got my dewitts radiator and wonder if there's anything that I might need to know that is hard with removing the old radiator. I tried to search for any reference but really couldn't find anything. I'm going to take my time putting it in. I ordered the radiator from A & A Corvette in Oxnard Ca. Great service and the radiator came very quickly since Dewitts had to build it for me. I just wanted to say thanks.
Old Aug 2, 2012 | 04:23 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The swap out is very easy without any real problems. If you are using the stock fans, you will have a small bit of trimming to do. Near one of the bottom brackets you will have to remove a small bit of the fan plastic for clearance - approx 1/4" X 1/2". I think it was the lower left hand bracket. Trial fit and trim before installing in car. While you have it torn apart, consider replacing the hoses and clamps. Get rid of the compression clamps that lose tension and use some good stainless screw band clamps. Also replace your AC and serpentine belts while everything is apart, it's very easy then.
Old Aug 4, 2012 | 03:29 PM
dlind4's Avatar
dlind4
Well I put the radiator in yesterday. I drove it about 45 miles since and temps are running at 205. It is about 100 degrees here so I think the temp is good. I just want to give a tip to help bleeding the air out quicker. When you have the car on jackstands remove one of the right top small radiator hoses and fill till you get coolant coming out. Without removing one of the hoses the air can't escape and it takes longer. When I did this I didn't have to add much at all. Now it's time to take another ride.
Old Aug 4, 2012 | 06:04 PM
slant's Avatar
slant
For the price of a Dewitts , you should not have to modify anything.
Tom , do you have an answer for that ?
Is it an oversight or is there a reason ?
Old Aug 5, 2012 | 04:05 AM
dlind4's Avatar
dlind4
Well in Toms defense the radiator is about 2 thirds bigger than the stock one width wise. You have to trim the left top and right top of the fan assembly but it's not much. Not hard and he sends a diagram that shows what you need to trim. Other than that the radiator fits perfect. Mine slid right in just like the stock one. Maybe it went in too easy because it was harder taking out the old one than putting in the new one. I now have about 80 miles on it and on the highway my temps are 199.
Old Aug 5, 2012 | 04:18 AM
slant's Avatar
slant
I have one too.
No diagram was in my box.
Even so , I still would like his answer.
For that kind of money seems like it should drop in.
I eargerly await his response.
Old Aug 5, 2012 | 04:51 AM
dlind4's Avatar
dlind4
The fans were designed for the single core radiator. Like I said the radiator is wider than the stock one. I don't know why they put such a crappy single core plastic end radiator in a corvette. Mine is a 2004 and you would think it would have lasted longer.
Old Aug 5, 2012 | 08:10 AM
sunchaser73's Avatar
sunchaser73
OP...did you change the thermostat at the same time? I've been thinking about getting a DeWitts for my C5...
Old Aug 5, 2012 | 08:21 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have one too.
Tom has said on here a few times that no trimming is required but just like the OP I had to make a few minor adjustments. Very happy with the radiator just sharing my experience. I have seen a few other posts like this. BTW I also have the SPAL fan kit which I just added a few months ago fits like a glove and does a great job although on the hottest days I can still see my temps climb to 230-235 if I am running my AC....keeping these Maggie cars cool is a real challenge
Old Aug 5, 2012 | 08:25 AM
molten vett's Avatar
molten vett
Default spal fan kit
Question. Did you install spal fan kit on your stock radiator? I was wondering if this would work.
Old Aug 5, 2012 | 08:26 AM
vettenuts's Avatar
vettenuts
Curious about this as well and what the outside temp is.
I modified my own thermostat and my car with the DeWitts cruises at 180. The motor temp only goes up when I stop at lights or am moving real slow. However, it drops right back down again. On cold days it runs at 178.
Old Aug 6, 2012 | 09:28 PM
slant's Avatar
slant
Tom , do you have any response to this ?
Old Aug 6, 2012 | 10:50 PM
lucky131969's Avatar
lucky131969
Old Aug 7, 2012 | 11:05 AM
waddisme's Avatar
waddisme
When I did mine last week, it was too late at night to fire it up and burp so I left the cap off to finish the next morning. When I returned, the coolant level had dropped so I filled to neck and did the 1 min uncapped, up to temp drill and no more coolant was needed. I guess it will burp itself if you are not in a hurry.
Old Aug 7, 2012 | 01:22 PM
lucky131969
No.....it won't.
Old Aug 10, 2012 | 09:57 PM
slant's Avatar
slant
I just drill a small hole in the t-stat
No burp required
Old Aug 10, 2012 | 11:22 PM
lucky131969
No burp required
Ya, right. If you have air trapped in a passage, it cannot magically leave a closed system.
To radiator removal
Old Aug 11, 2012 | 08:13 AM
vettenuts's Avatar
vettenuts
You really seem to have an ax to grind over the DeWitts radiator, not only here but in other threads as well. I can't think of very many mods I have done where some changes were not required to put things back together. The DeWitts radiator was the most minor of any of them, the FAST was major rework. If you find the trimming of the fan shroud such a hassle, better not do any more mods to the car.
If you don't want to make this minor adjustment, why not leave in the GM "drop in"radiator?
Old Aug 11, 2012 | 09:06 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You should have gotten a sheet on trimming the corners, obviously we didn't do that. If you email me I can send you one. The ABS fan shroud can be installed onto the radiator without trimming the corners but they will hit the top rail and bend back. If you trim out a 1/2 x 1" piece, it lays flat. We designed it this way to keep the shroud as tight as possible so it would seal up against the radiator.
Old Aug 11, 2012 | 10:31 AM
slant's Avatar
slant
No ax , just want info
What des an intake have to do with a radiator ?
I already have the Dewitts , reading is fundamental
I don't consider a radiatior a "mod" either
Thanks to Dewitts for the pics.
