Stock Water Pump Longevity
Old Aug 3, 2012 | 12:26 PM
C5Natie's Avatar
C5Natie
Default Stock Water Pump Longevity
Hey guys, my water pump is going on 86k miles and I have yet to see a cooling issue with it. Yesterday was a hot day, oil temp was 220 and yet the cooling system stayed at 187. Thats with a stock radiator too. I was wondering if should leave it in till it croaks or leaks or should I replace it to be safe? For those who have changed theirs, how long did it last? Thanks.
Old Aug 3, 2012 | 12:58 PM
egrand333's Avatar
egrand333
My friends 99 has 148,000 mi. on the origanal water pump.
Old Aug 3, 2012 | 01:36 PM
AFTRBRNR's Avatar
AFTRBRNR
108k on stock pump with highly modded engine... I have a 160 degree thermostat and I run 178 cruising in summer 174 in winter and never goes above 210 when sitting. My oil and trans temp usually never exceed 210.
I took it off last week to replace my ac compressor, the pump is a PITA to put back on but can be done in the driveway. Changing the thermostat is very easy.
Old Aug 3, 2012 | 02:44 PM
Vettmann17's Avatar
Vettmann17
Replaced mine at 80K because of leaking. I certainly wouldnt repair anything that wasnt broken, no reason to.
Old Aug 3, 2012 | 02:46 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
^^^^^^^^^all the above...its a crapshoot
Old Aug 3, 2012 | 03:08 PM
helga203's Avatar
helga203
Me to 82k started leaking
Old Aug 3, 2012 | 04:49 PM
slant's Avatar
slant
Mine lasted around 190k
Old Aug 3, 2012 | 06:36 PM
C5Natie's Avatar
C5Natie
Well it looks like the majority of them last a long time. Good news because they arent cheap.
Old Aug 3, 2012 | 06:45 PM
Corvette_Ed's Avatar
Corvette_Ed
As the saying goes, "If it ain't broke, don't fix it."
Another saying to pay attention to: When you hear a Texan say, "Hey guys, watch this!"......run like hell.
Old Aug 3, 2012 | 08:33 PM
WKMCD's Avatar
WKMCD
Mine gave up the ghost at around 50k. Don't really think there is an average life for these things. It's the first water pump I've replaced on a car in 30 years.
Old Aug 3, 2012 | 08:47 PM
slant's Avatar
slant
I see them for around 80-100 bucks , that isn't too bad
Old Aug 3, 2012 | 08:50 PM
boltnut's Avatar
boltnut
Mine is just about to hit 100k
Old Aug 3, 2012 | 09:08 PM
C5Natie's Avatar
C5Natie
Hmm, i gotta do more shopping around because I saw a few for $130-150. Its not too bad but I was remembering how much cheaper they were on sbc.
Old Aug 3, 2012 | 09:37 PM
Cybermind's Avatar
Cybermind
I wonder what the connection (if any) is between water pump longevity and people that switched their coolant over to regular green glycol. I've read that the GM Dexcool does wonders for water pump longevity and that switching over to conventional glycol coolant shortens the water pump life. Any comments?
Old Aug 3, 2012 | 09:59 PM
C5Natie's Avatar
C5Natie
Ive been running distilled water with two bottles of water wetter for a few years now with no issues.
Old Aug 3, 2012 | 10:00 PM
dankhts's Avatar
dankhts
Dexcool is an aid to longer water pump life as is any other "extended life" coolant, compared to regular glycol....all anti freeze contains rust inhibitors and certain lubricants, all of which will wear out in time, they just last longer in extended life coolants, hence the recommended change interval is longer....a water pump will pretty much always pump water, they just eventually leak because of bearing and or seal failure....because the rust inhibitors and lubricants dissipate.......if you change your anti freeze according to the manufacturers recommendation, the water pumps will last longer - so will the rads.... Or, you could do what's very common in the trucking industry - take coolant samples regularly, sort of tests the PH level of the coolant...and add additives as required ( nalcool etc) .... Anti freeze itself really never wears out, just the additives dissipate over time due to constant heat and cool cycles.....then you get the water pump leaks....
Old Aug 3, 2012 | 11:11 PM
CARMINEVETTE's Avatar
CARMINEVETTE
I had to change the pump at 85,000 due to a leaky pump seal not too long after I changed and flushed the cooling system. I replaced it with a new after market pump. At 114,000 no problems.
To Stock Water Pump Longevity
Old Aug 4, 2012 | 06:21 AM
pewter99's Avatar
pewter99
depends on where ya buy it
Old Aug 4, 2012 | 06:24 AM
pewter99's Avatar
pewter99
tell that to the waterpump on my girlfriends 02...we just replaced the entire cooling system not 2 years ago and the fkin waterpump is weeping again.....this will be the 6th waterpump for her car....140K....my 99 is on number 2
I have seen people on here replace them with 15K.....30K....100K and others well over a 100K with no issues....
I have no freaking clue why her car kills waterpumps
Old Aug 4, 2012 | 10:36 AM
slant's Avatar
slant
Usually it's belt tension , but not on a vette.
