Pressuring the oil system
Old Aug 9, 2012 | 06:31 PM
leaftye's Avatar
leaftye
Default Pressurizing the oil system
Is there a way to pump oil throughout the engine without turning the engine over? Older cars let you use a drill to run the oil pump.
Old Aug 9, 2012 | 06:38 PM
brickhammer's Avatar
brickhammer
On fuel injected engine, hold pedal to the floor and turn engine over. Car will not start and pump the oil threw it. I do this after oil change..
Old Aug 9, 2012 | 06:46 PM
leaftye's Avatar
leaftye
Edited my post. I want to run oil without turning the engine.
Old Aug 9, 2012 | 08:45 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I would not have guessed this. I could envision my car pinning the tach with no oil pressure!
Old Aug 10, 2012 | 09:26 AM
feeder82's Avatar
feeder82
thats what will happen
Old Aug 10, 2012 | 09:51 AM
lucky131969's Avatar
lucky131969
Why do you say that?
Old Aug 10, 2012 | 01:42 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
There is a threaded plug located on the left side of the block, near the front. You can remove the plug, and pressurize the oil lubrication system by the method of your choice.
Old Aug 10, 2012 | 03:39 PM
3boystoys's Avatar
3boystoys
They sell pre-oilers
Old Aug 10, 2012 | 03:54 PM
Paul 75 L82's Avatar
Paul 75 L82
I just unpluged the injectors and spun it a couple of spins till the gauge moved.
Old Aug 10, 2012 | 03:58 PM
Quicksilver Vert 01
Did you read post #3?
Old Aug 10, 2012 | 04:21 PM
slant's Avatar
slant
Old Aug 11, 2012 | 03:30 AM
leaftye's Avatar
leaftye
Thanks for the help. Last time I was active here, A&A had the only pre-oiler. I'd love one at some point, or a full on dry sump system, but unfortunately it's not going to happen right now.
Old Aug 11, 2012 | 10:33 AM
slant's Avatar
slant
Accu-sump has been around for a long time
Old Aug 12, 2012 | 08:54 AM
Qweklain's Avatar
Qweklain
Is this actually true? Can anyone confirm this? I do not doubt it, but I do not know either and can not say I have heard of it. Then again, I do not know too much on the newer EFI stuff.
Old Aug 12, 2012 | 10:32 AM
brickhammer
It's true, try it with the oil in it before you change it. Been doing it for years.
Old Aug 12, 2012 | 01:28 PM
RonSSNova's Avatar
RonSSNova
Guys have rigged up an old SB or BB chev oil pump some lines, a drill motor and a bucket of oil. If you had a remote filter adapter, you should be able to prime the pressure side of the engine.
Ron
Old Aug 12, 2012 | 02:00 PM
lucky131969
Yes...you can! It's in your service manual. It's called "clear flood mode" for the PCM.
Old Aug 13, 2012 | 10:45 AM
waddisme's Avatar
waddisme
When I built my forged motor for road racing, I put the 3 qt accusump on it. I rarely have pressure issues at track, so pump doesn't get much work there, but it is also a dd, so I pre oil every morning before starting - 23lbs. You can pick up complete systems every now and then for around $300 in for sale section. Even new is not that expensive when you are talking about $5k (or $15k) motor. Not too hard of install.
To Pressuring the oil system
