Coolant leak HELP!
Old Aug 17, 2012 | 11:02 PM
high wire's Avatar
high wire
Originally Posted by Purple92
Probably OBE - but I would suggest one of two things:
1. Stop by a well equipped auto parts store and get a little bottle of dye for detecting coolant system leaks. Pour it in - and drive the car a bit - then look for the leak with a blacklight. Typically you'll want to do that at night. The leak will typically be VERY easy to find.
2. Get (buy or borrow) a cooling system pressure tester. It allows you to put presure on the cooling system while the car is off. It will make finding a leak that only shows up under pressure far far easier.
I would hope the school would have one you could at least borrow. Doesn't the school have a shop you could use ?
Old Aug 18, 2012 | 05:27 PM
vetteboy850's Avatar
vetteboy850
This is what was causing my coolant to leak
