Wheel Track Alignment
Old Aug 17, 2012 | 08:26 PM
sbadd99's Avatar
sbadd99
Default Wheel Track Alignment
My 99s wheel track is out, the left front wheel is 13mm closer to the front of the wheel well than the right side, measured from wheel centers both sides, can a wheel alignment correct this, with 19" front the left rubs on the inner when turning right.
Old Aug 17, 2012 | 10:59 PM
high wire's Avatar
high wire
Something is way out of whack. It is possible to do this with an alignment if nothing is bent. If something is bent , more drastic measures will need to be taken.
Old Aug 17, 2012 | 11:02 PM
Lothar34's Avatar
Lothar34
Are you sure the plastic in the wheel well is on securely? I can't imagine the suspension being off by that much.
Old Aug 18, 2012 | 06:57 PM
sbadd99's Avatar
sbadd99
Thats what I though align it out thanks nothing bent been like that for many years, dosn't cause a problem other than I want to correct it, just brain storming and yes I do know who to measures
Old Aug 19, 2012 | 03:33 AM
Lothar34's Avatar
Lothar34
The thing is that the A-arms mount both to the subframe and to the frame rails. So if the subframe or the frame rails were somehow twisted, then the bolt holes wouldn't match up. If BOTH were twisted - and I don't see how that could happen without causing a host of other problems - then maybe.
Can you take pictures of both sides?
Old Aug 19, 2012 | 03:56 AM
high wire's Avatar
high wire
Possibly a bent ball joint ?
Old Aug 19, 2012 | 04:49 AM
Lothar34's Avatar
Lothar34
I can't imagine that they'd be able to bend. They're pretty short and really stout. Maybe if one was completely broken, but if that was the case you'd surely notice any time the suspension moved.
Old Aug 19, 2012 | 07:44 AM
AU N EGL's Avatar
AU N EGL
Measure center of Rear wheel to center of Front wheel
Both Left and Right sides then compare
Old Aug 19, 2012 | 12:37 PM
high wire's Avatar
high wire
See post #1. He said he did. 13mm off.
Old Aug 19, 2012 | 01:45 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
No, he didn't say that...
He said he measured from the centers of both front wheels, to some point in the wheel well.
You're correct, however, that he should "wheelbase" the car, by measuring from the center of the front wheel hubs to the center of the rear wheel hubs on each side of the car, then comparing these numbers. However, that can get tricky, unless you have a way to get the front wheels both pointed straight ahead, and at "zero" toe.
Old Aug 19, 2012 | 04:12 PM
sbadd99's Avatar
sbadd99
Yes I did say that
Will post when I find the error
Old Aug 19, 2012 | 05:50 PM
high wire's Avatar
high wire
You'd be surprised. I've seen many bent ones. Especially with condition of the roads nowadays. Potholes , expansion joints , cracksjust keep getting worse as the infrastruture falls apart.
Old Aug 19, 2012 | 08:47 PM
Assassinx1's Avatar
Assassinx1
its probably the engine cradle is moved forward or backward to far on one side I had the same problem. Mine was to far to the left. The left wheel was out 1/2 inch on one side and in 1/2inch on the other. Dont take ti to the dealer they wont know how to do the job correctly. I went 4 times 3 different dealers. Finnaly took it to euro tire for a custom alingment. Car drives strait as an arrow now.
Old Aug 19, 2012 | 10:44 PM
lionelhutz's Avatar
lionelhutz
The cradle should be aligned with dowel pins unless someone messed with it.
The ball joints on the lower a-arms can be moved forwards and backwards by moving the arms on the alignments cams.
I'd say do some front to back and triangulating measurements between the front and rear subframes. Then, look into shimming the upper arms and then adjusting the lower arms to move the wheel back if the subframes are in the correct locations.
You may end up with the wheelbase different on each side of the car to get the wheel in the correct location in the wheel well. The inner fender structure might be glued on a little out of place.
Old Aug 19, 2012 | 11:47 PM
Assassinx1's Avatar
Assassinx1
Yes except the dowl pins are roughly 3/8 thick and the cradles holes that slide over the dowels are roughy 5/8 to a 1/2 inch. There is enough movement that if shifted to one side will be noticeable.
Old Aug 19, 2012 | 11:49 PM
Assassinx1's Avatar
Assassinx1
Also don't forget the whole front fenders and nose can be moved too. The car could simply need all of the mounting bolts for the front nose and fenders loosened and moved forward slightly on one side of the car.
Old Aug 20, 2012 | 10:00 AM
lionelhutz's Avatar
lionelhutz
LOL, try again. The inner fender structure is glued onto the car. You'd be OK with a 1/2" more gap between the fender and the door if you could move it?
I've had the rear cradle out a few times. There was not 1/4" play in the dowel holes like you're indicating on the rear.
Old Aug 20, 2012 | 10:27 AM
Assassinx1's Avatar
Assassinx1
Hmm. Mines a 98 I can move the fenders and the cradles what years are yours? Not to jack the thread I'm just curious.
Old Aug 20, 2012 | 04:32 PM
sbadd99's Avatar
sbadd99
interesting ideas will have a closer look next weekend, thanks
To Wheel Track Alignment
