C5 overheating
Old Aug 20, 2012 | 04:50 AM
1813dave's Avatar
1813dave
4th Gear
Default C5 overheating
My 2000 Vet was 10 yrs old when I purchased it with very low mileage.
It need alot of maintenance. One item was to add new antifreeze. After that I noticed it was running hot, too hot. I read the threads about over heating and learned to bleed the heads. This was the answer to my overheating. I did have to bleed each head 3 times...
Old Aug 20, 2012 | 07:34 AM
runner140*'s Avatar
runner140*
Your question.....it had air in the system and you bled it out or its still overheating?
Old Aug 21, 2012 | 12:04 AM
kalayaan12's Avatar
kalayaan12
You might want to look up under the front of your vehicle where evaporator and radiator are housed just to double-check?
About 2/3rds of my evaporator was absolutely packed with all kinds of windblown junk - most of it consisting of those darned Cottonwood seeds that drift all over in the place!
I've heard that plastic bags like to get caught up in there as well...
Jeff
Old Aug 21, 2012 | 08:38 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I read it as he bled the air out and solved the problem which means this post had no reason except to tell us he had a problem and solved it
To C5 overheating
