Code C1226
Old Aug 21, 2012 | 02:05 PM
bubs99's Avatar
bubs99
Default Code C1226
Code C1226 comes on everytime I hit a bump. Does this mean that I need to replace the passenger front hub?
Thanks Bub
Old Aug 21, 2012 | 02:25 PM
87SAM's Avatar
87SAM
Maybe. You should first check for a damaged, loose or corroded connector.
Old Aug 21, 2012 | 03:06 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
If you have to replace the hub its better to do both at the same time. Its not a hard job. Check and see if the connector is corroded.
Old Aug 21, 2012 | 03:50 PM
bubs99's Avatar
bubs99
will do thanks
To Code C1226
