Paging C5-TECH- Help With Code
Old May 30, 2002 | 10:03 PM
BIGMAC2's Avatar
BIGMAC2
Default Paging C5-TECH- Help With Code
Last weekend my baby threw the following DIC code:
28-TCS
C1281H Steering Sensor Uncorrelated Malfunction
WTF?
:confused: :confused: :confused:
Do I need to take it in to the dealer? Is there any DIY steps to take? Can I ignore this?
Old May 30, 2002 | 10:22 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Paging C5-TECH- Help With Code (BIGMAC2)
Faulty steering position sensors are common,causing this code :yesnod:Replacing it requires removing the steering column because the sensor is located around the base of the column...Before you tackle this,clear the code and see if the message returns on a frequent basis,in that the sensor may have put out an intermittent voltage spike detected by the brake control module...
