Problem w vats system
Old Aug 31, 2012 | 06:51 AM
speedygc5's Avatar
speedygc5
I was told it was the vats system but still the same exact thing.
Old Aug 31, 2012 | 08:24 AM
F-2's Avatar
F-2
Originally Posted by speedygc5
Yes. Sometimes it cranks and cuts right back off. Like if the computer is cutting the fuel.
Cuts off while your still trying to crank it????
Old Aug 31, 2012 | 09:45 AM
speedygc5's Avatar
speedygc5
As soon as it cranks it shuts off.
Old Aug 31, 2012 | 10:06 AM
lucky131969's Avatar
lucky131969
Why do I feel there is a terminology problem here?
With regards to the engine:
1) Engine rotates using the starter = "cranks"
2) Engine starts = "fires" ; "engine running"
Old May 6, 2017 | 05:12 PM
2010Pony's Avatar
2010Pony
On my 1988 had the no crank and had to wait couple hours to start. Got VATS bypass from corvette central you plug into lower steering column. Worked for a while than started have more issues. Replaced the starter from AutoZone and bypassed starter enable relay in back of information center. Look up VATS sucks and it will give you all information on how to do it. Easy and takes about a hour. No problems since
