selective ride help
Old Aug 29, 2012 | 02:59 PM
rbrumm's Avatar
rbrumm
Default selective ride help
I disconnected one of my my selective ride shocks to work around my wheel I put everything back and now i have a screen warning
"service selective ride system" I had more messages "shocks inopertive" etc but those went away after a cruze around the block how do I get rid of that last message
Old Aug 30, 2012 | 12:38 PM
rbrumm's Avatar
rbrumm
Originally Posted by 8VETTE7
There's an old saying that the last thing you touched before encountering a problem is the MOST LIKELY cause of the problem.
I suggest you go back and inspect the wiring and the pins on the connector halves that you disconnected and reconnected....................
I will do that .... hopefully everything will jump back to normal
thanks
Old Aug 30, 2012 | 03:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the FEMALE PINS in the female side of the connector and make sure that they are not spread apart and making poor contact with the male pins. You didnt put dielectric grease in the connector did you???
Old Aug 30, 2012 | 11:19 PM
rbrumm's Avatar
rbrumm
I'll pull the plugs this weekend and make sure everything looks ok. And no grease in the plugs does it do any good to disconnect the battery to reset?
Old Aug 31, 2012 | 06:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just clear the DTCs from the DIC. No need for battery disconnect
BC
Old Sep 1, 2012 | 01:03 PM
rbrumm's Avatar
rbrumm
BC
I'm a delete code rookie How do I do this
To selective ride help
